Question about York Yankees Bedding MLB Comforter
How to use the digital thermostat (honeywell)
I recently purchased a house the house has a YORK air conditioning system. The thermostat controls both of course. I having problems trying to turn the heater ON. It seems that you have to setup a timer for the whole week. Can somebody please help me out. really cold over here.
  • soria_d Dec 23, 2008
    It's a Honeywell it has 4 arrows and two bottom switches. Next to the left arrow is the HOLD and the right is SETUP. The bottom left switch is for AUTO and FAN the right switch is the COLD OFF HEAT.
    I this is the information you need. the floor heaters I got in costco work ok for just one room.... lol....
  • 700 Answers
What type of thermostat is it, find out the model and or the make and i"ll be able to walk you thru
Posted on Dec 21, 2008
  • Todd Born
    Todd Born Dec 23, 2008
    would it be a t87a?
What does -AC on honeywell chronotherm III thermostat mean?
AC means "air conditioning." If the AC icon is showing on your thermostat it means that your air conditioning is activated and should come on when the temperature threshold you've set on the thermostat is reached.
For example, if you've set the temperature level to 78 degrees, when the house temperature goes above 78, usually by about two degrees, the air conditioner should cycle on to cool it back down to 78 degrees at which point it will then turn off.
This information should be in your air conditioning/heating system or thermostat owners manual. If you don't have the manual, you should contact your air conditioning dealer or your builder to secure a replacement. The manual is essential for proper operation and maintenance of your system.
May 14, 2014 | Heating & Cooling
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
How does one set a Honeywell ultrastat thermostat to cool a house. Ours wont shift into air conditioning
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 09, 2010 | Honeywell Electronic Programmable...
Need to program thermostat for air conditioning
well your system should automatically shut off when the thermostat reaches temperature, if it doesnt, then you need to look at possibly replacing the wall thermostat or the thermistor on the unit
Aug 17, 2009 | Honeywell TH4210D1005 Heater
A/C not turning on - Digital screen is blank
Your honeywell should have battery back up but the primary power for this is a 24 volt transformer located in the air handler probably in your attic. All these controls run on 24 volts
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Replacing Old York TS to HoneyWell RTH230B
rh is hot for heating rc is hot for cooling looks to me like ya need a heat pump stat some thing to control the reversing valve.Tom
Jun 18, 2009 | Honeywell Electronic Programmable...
Heat pump -> installing digital thermostat.
sounds like the thermostat is not energizing the reversing solenoid , unless you have some experience with electrics i recommend that you call a trades person, to check this problem a multi meter is required and requires the user to know how to work with power , please do not attempt it yourself ...
May 10, 2009 | Heating & Cooling
Air conditioning will not turn on
Look for a leak in the system, this is because, if you have a leak there is a low pressure switch that prevents the compressor to turn on when there is low or no refrigerant pressure.
Also, perform a pressure check, this is about 68.5 psi and 70 psi with the system and compressor running.
Jun 02, 2008 | Honeywell Electronic Programmable...
York Yankees Bedding MLB Comforter Logo
496 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
obsteiner
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
