Question about Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter
I have a PCMCIA adapter, the RICOH R5CA475 based thing. It causes this problem under LInux: Dec 21 00:13:10 who7 kernel: Linux Kernel Card Services 3.1.22 Dec 21 00:13:10 who7 kernel: options: [pci] [cardbus] [pm] Dec 21 00:13:10 who7 kernel: Intel ISA PCIC probe: not found. Dec 21 00:13:10 who7 kernel: Databook TCIC-2 PCMCIA probe: not found. Dec 21 00:13:10 who7 kernel: Yenta ISA IRQ mask 0x0000, PCI irq 10 Dec 21 00:13:10 who7 kernel: Socket status: 30000810 Dec 21 00:13:11 who7 cardmgr[2550]: watching 1 socket Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0c00-0x0cff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0820-0x08ff: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0800-0x080f: clean. Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x03e0-0x04ff: excluding 0x4d0-0x4d7 Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0100-0x03af: excluding 0x378-0x37f Dec 21 00:13:11 who7 kernel: cs: IO port probe 0x0a00-0x0aff: clean. Dec 21 00:13:11 who7 kernel: cs: memory probe 0xa0000000-0xa0ffffff: excluding 0xa0000000-0xa0ffffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x60000000-0x60ffffff: excluding 0x60000000-0x60ffffff Dec 21 00:13:11 who7 kernel: cs: warning: no high memory space available! Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0d0000-0x0dffff: excluding 0xd0000-0xdffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0e0000-0x0effff: excluding 0xe0000-0xeffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0c0000-0x0cffff: excluding 0xc0000-0xcffff Dec 21 00:13:11 who7 kernel: cs: memory probe 0x0f0000-0x0fffff: excluding 0xf0000-0xfffff Dec 21 00:13:11 who7 kernel: cs: unable to map card memory! Dec 21 00:13:11 who7 kernel: cs: unable to map card memory!
2 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Stop 7
I know Ricoh hasn't been supporting these for some time now. Do you have a set of drivers for this device?
Posted on Aug 05, 2008
What is the Android Architecture?
The Android Framework is an important aspect of the Android Architecture. Here you can find all the classes and methods that developers would need in order to write applications on the Android environment. Real Time Live IEEE Project Project Titles Projects Titles Projects...
Jun 09, 2014 | Broadcom BCM94306MP - IEEE 802.11b/g...
I cann't find device driver of RT2070 Chip usb type dongle.linux
http://www.opendrivers.com/freedownload/283907/ralink-rt3070-rt2070-wireless-usb-driver-2.2.1.0-1.2.1.0-windows-2000-xp-vista-download.html
http://www.freeos.com/articles/2677
http://network.free-driver-download.com/ralink.html
go for this thre website then try it
go for it
Mar 30, 2009 | Computers & Internet
Kernel Cardbus card (YENTA socket) problems
Dear
With many distributions with the later 2.4.x kernels (>2.4.15 I think), the PCMCIA cardbus services has been merged into the kernel with the YENTA socket. While this works with most laptops it also have problems with many others. Usually, the kernel messages will state that the card is detected correctly but then the ard will not respond to any ping messages in or out.
If your laptop does have this problem then you will need the older modular cardbus services through the PCMCIA-CS package. The information and source can be found at the Linux PCMCIA Information page. The solution for this is not for the faint of heart. It requires a recompilation of the kernel in order to disable the kernel PCMCIA implementation and install the PCMCIA-cs as a module. Again, the best source for Linux information such as kernel compilation can be found at the Linux Howtos. Also, Linux on Laptops provides many useful information on installing Linux on laptops
As of 2006/2007, the Yenta socket in the 2.6 series kernel is quite stable. It should now works properly with most if not all previously unsupported laptops.
Screen garbles after changing between X Windows and console
This is a relatively common problem with Linux on laptops. In the kernel call line in Grub or LILO, make sure that the vga=7xx line is included so that the kernel locks to a particular native LCD resolution. Some common vga= values for 16-bit color are:
800x600 vga=788
1024x768 vga=791
1280x1024 vga=794
Oct 19, 2008 | Computers & Internet
Apache Linux Problem
It means that apache want to use SysV IPC. (semaphore get function)
IPC:
Inter process communication
These software objects (semaphores,shared memory and signals) enables the processes to exchange information.
Apache processes wants to exchange information via semaphores but could not,
You current Linux kernel dont have SystemV IPC support.
You should build a new Linux kernel with a SystemV IPC support.
You will have to rebuild the kernel with that support enabled (it's under the "General Setup" submenu)
I hope you can compile a new Linux kernel, if not this can help:
http://www.freeos.com/articles/2589/
Sep 16, 2008 | Apache HTTP Server
Stop 7
Aug 05, 2008 | Ricoh R5CA475 PCMCIA to PCI Interface Card...
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Need network drivers
1st of all r u using onboard lan?
n r u using desktop or server pc?
if u want something so u'ave to know what u actually want n give abit brief information abut it!
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2837&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go%21
download the driver from this site if its not working so then wait to intel coz they havent made drivers of ur lan for linux yet!
Nov 05, 2007 | Intel Motherboard
Intel PRO/Wireless 2200BG Network adapter not recognized
Hi
Check Intel PRO/Wireless 2200BG Downloads - http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1637
Select Linux from and click on go
You can download Intel PRO/Wireless 2200BG version 1.2.0 or 1.1.0
Installing/updating Intel PRO/Wireless version 1.2.0 driver for Linux
- To extract the archive file, type from a console: tar xzvf ipw2200_linux_1_2_0.tgz
- To install the driver the following is needed:
1. Linux with a 2.6.8+ kernel. See README.ipw2200 for information on
specific options required to be enabled in the kernel.
2. Wireless Extensions (v16) and Tools (v27-pre23) if not included in
your distribution
3. The driver (ipw2200-1.2.0.tgz)
4. The binary firmware image (ipw2200-fw-3.0.tgz)
5. For instructions on how to build and use the driver, please see the INSTALL document in the ./intel_ipw2200_120/ directory.
More info http://ipw2200.sourceforge.net
Regards
Mike
Oct 01, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Need an updated Linux driver for WF748-UIc
http://zd1211.ath.cx/wiki As per that website, the drivers are now included in the Kernel since 2.6.18. If you're manually compiling your kernel, you can find the module in the menuconfig of the linux kernel source (ie in the `make menuconfig` menu) in: Device Drives -> Network device Support -> Wireless LAN (non-hamradio) -> Wireless Lan Drivers -> USB ZD1201 based Wireless device support
Jan 19, 2007 | GigaFast Ethernet WF748-UI (WF748UI)...
Ricoh R5CA475 PCMCIA to PCI Interface Card Adapter (CL-PCM012) Serial Adapter Logo
125 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Marvin
Marvin
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
