Question about Philips Magnavox 20MT133S 20" TV
Repairing a broken green components board
Hi I have a dec television for which i had to replace the reciever. the problem is when i was taking the reciever out I broke the green board the all the components are soldered on to. could you please explain to me how i can repair this as the repairer has advised me that eventhough the tv is only 2 years old, they dont make them any more, thus they dont have the same components left. I dont have much money to get it repaired so i was hoping you could give me a detailed explanation on how to repair the green board thanking you in advance foxtroi
  • 944 Answers
First thing to do is let us have all the information that is printed on the broken board. we will first see if we can find one for you - most of these can be found for years after they have stopped making the set, and often another company will buy the license to carry on making them under a different name. Usually the boards bought seperately are relatively cheap. If we have no luck finding a replacement, then the repair may be possible depending on what the damaged part is - if you can remove the damaged board, take a couple of close up photographs of each side complete and really close up of the damaged area, post them back here and we can hopefully advise you if it can be done and how to do it. Almost certainly you will need a reasonable electronic soldering iron and possibly a solder removing suction plunger - these tools are cheap enough if you only need to use them a couple of times. The skill level required will depend on the exact nature of the damage, but hopefully we can talk you through the job. First give us the details of the broken board and take a few photos - then we can see what we can do. waiting for your reply :)
Posted on Apr 06, 2007
Green light comes on for 3 or 4 secs, then yiu hear power off and it returns to standby
Hello
Power regulator board inside it has damaged. In most cases, this board is irreparable due to unavailablity of components. Replace the board as card basis. Especially plasma TV boards are very complicated in circuit nature, and cannot be repaire without getting proper components. No substitutions will go on with these power supplies. So replace the power supply board with same type and number. You can get it from Authorised Service Center for Sharp at your town. OK.
Jun 23, 2011 | Sharp Aquos PZ-43HV2U 43 in. Plasma...
MY TV DOES NOT SWITCH ON - NO RED OR GREEN LIGHT IS SHOWING
Power Supply Board needs replacement.If you need complete power supply board then click here and find the board according to the product name and complete model number and you will find all the details, If you need repair on component level then contact repair man to resolve the issue of power supply.
Thanks
May 12, 2011 | Televison & Video
I have a HCM4216W rear projection tv. It was
The convergence IC have gone bad, bad solder connections to IC or probably both. The board as a whole can be purchased as complete (look to the web to find where to get) and is fairly easy to replace. Unless you have extensive experience with component level repair I would suggest you take the board to a TV shop to repair. This option maybe slightly less then replacing board. Check with your local TV repair shop to see which option is the best in your area.
May 06, 2010 | Samsung HCM4215W 42" Rear Projection...
I have the same green light blinking issue. the tv won't power up
ouch, it cost them $300 to have the chassis rebuilt, if they want that kind of money kick it to the curb.
Aug 17, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Convergence way off!
Yup, you lost convergence. The only fix is to repair/replace the convergence IC. Some techs will just replace the whole video board.
Nov 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Akai Plasma PDP4273M with white block and green tint
I have the same problem with mine. I had a repair guy come by and take it apart. He said its either the video board ( about 500.00 ) or the buffer chips which on these tvs are connected to the screen which is not worth the money to fix.
Jun 15, 2008 | Akai PDP4273M Television
No raster, no sound on 53UWX10B
double check the wire connections, as the filaments not being lit makes me thing a wire isnt connected properly, or one may have been loosend while doing the convergence repairs.
Jun 12, 2008 | Hitachi 53UWX10B 53" Rear Projection...
RCA 52" second time in the shop in less than one year, won't stay on, green light flashes 3 times then goes out
try changing the cap 150 on the same board as flyback transformer this should help with the tv not staying on.
Jan 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hdtv/ direct tv service
more then likely you are using component input if you are check to make shore they are hooked up correctly red to red green to green and blue to blue if they are you might have a bad cable I have not seen a color stream board bad yet
Oct 16, 2007 | Toshiba 50HX70 50" Rear Projection...
Philips Magnavox 20MT133S 20" TV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
