Question about Whirlpool AWM029 Front Load Washer
Whirlpool awm049 washing machine
I cleaned out the filter and found a sock. now i can't get the filter cap back on. any ideas
  • LMIT May 11, 2009
    Water Stop light comes on. Any idea what the cause might be?
    President:
  • 1,462 Answers
Just perseverence. being wide diameter it is sometimes hard to start the thread. what exactly is preventing you
Posted on Apr 04, 2007
Whirlpool duet sport washer code f21
May be more socks stuck again. Best thing to do is check the filter once a week if it's on the outside of the machine. The ones that are not easily accessed usually don't get touched till a problem arises so to stop small items disappearing and ending up in the filters get a small net bag that has a good form of closing it to put the small items in and then stick the bag in the wash.
Dec 31, 2012 | Whirlpool Washing Machines
Tip
This saved my a phone call to my plumber. In the filter itself, I found a...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Mar 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont drain
Drain hose clogged, or pump has quit or switch to turn on pump has quit.
My first idea hose clogged, unplug power, run a coat hanger through hose, May have to disconnect hose
I once found a baby sock in the pump itself.
Hope these ideas help.
Jul 08, 2012 | Whirlpool WTW4850XQ Washing Machines
The washe is flashing F-21.
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 12, 2011 | Whirlpool AWM9000 Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool Ultimate Care II still won't drain
More than likely you have another garment in the pump or connecting drain line.
Check it all again.
Nov 10, 2008 | Whirlpool Ultimate Care II GSQ9669L Top...
I have an LG WF-T552A Washing machine it wont drain water from the spin cycle and the letters OE comes up on the screen
your washing machine has a sediment trap in the bottom of it. if you take off the bottom plate you will see a cap/plug with hoses going into the back of it open the cap and clean it out. be ware lots of water will come out, i had the same problem and found 2 of my 1 year olds socks in it
Sep 26, 2008 | LG Washing Machines
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Would help if you were more specific.....
Apr 04, 2007 | Whirlpool AWM029 Front Load Washer
Whirlpool AWM029 Front Load Washer Logo
177 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
