Question about Atari 2600 Console
Paddles don't work for atari 2600
My atari paddle controllers don't work in the left port, or at least the second atari paddle controller in a combined set don't work. The joystick works jsut fine but the right paddle don't. I know it isn't the controllers bec. they work in the right port.
Sounds like a pin has come loose from the main board inside your unit. If you are handy with a soldering iron, and not opposed to opening up your console then, you can take a look at the connection between the connector and the board... If you are not comfortable with this idea, then you can find a competent electronics repair shop on the internet. You could also replace that unit with a "new" one from a number of internet shops or eBay, then retire that one. Hope this helps.
Posted on Dec 22, 2008
Regardless of controller on the left controller port i cant move up
Well it sounds like the controller that you have is not working properly so you could buy a new controller then. Lukie games sells atari 2600 stuff. Or you could open up the controller and try re soldering it the. To see if it works
Apr 29, 2012 | Atari 2600 Console
I plug my atari controller into the system and the button works but the joystick does not. No matter which direction I try to move in the character remains motionless. I have tried multiple controllers...
Well it might be the controllers ports inside of the system that are broken then so you could
try and resolder the controller ports if not buy a new one then.
Nov 06, 2010 | Atari 2600 Console
I have an Atari 2600 console. The Player #1 slot is stuck in the firing position. It is not the joystick. I swapped out joysticks and no change. It is something with the console. What can I do to fix this?
Well the controller ports inside of the console might be needed to be resoldered or the controller ports might be broken or it could be just bad controllers then.
Oct 09, 2010 | Atari 2600 Console
No color in the games
Well try buy a new rf switch to see if it makes a difference then.
Mar 07, 2010 | Atari 2600 Console
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
ON my atari 2600 my paddlel controlers don't work in the left port. but my regular joystick dose. what do i do?
Unless you are an electronics expert with a soldering iron, I would just get a replacement paddle from eBay or online seller. I occasionally experienced this problem in the early- to mid-1980s - getting new paddles always did the trick. If you are up for a challenge, look at the joystick pin and then look at the paddle pin - you will see at least a one-pin difference between the two. Check the paddle pin to see if one is physically damaged, then compare the pin on the console itself. Have fun!
-Tha Mp3 Doctor
Dec 21, 2008 | Atari 2600 Console
Atari 2600 jr. console + paddle controls = DonĀ“t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Possible Control Port Issue for 2600
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Sep 04, 2008 | Atari 2600 Console
Atari 2600 controller problem
I HAVE BEEN REBUILDING ATARI SYSTEMS FOR 20 YEARS AND THOUGHT I HAD SEEN EVERYTHING, AND I WOULD THINK IT TO BE A JOYSTICK PROBLEM. THEY CAN BE REBUILT WITH NEW CONTACTS, BUT I AM THINKING THE PROBLEM MUST BE INTERNAL. I CAN ONLY SUGGEST TRYING ANOTHER DECK. THERE MUST BE SOME PROBLEM WITH THE PINS IN THE PLUG PORT.
IT
Oct 19, 2007 | Atari 2600 Console
Atari 2600 Console Logo
233 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
ebaypolenz
ebaypolenz
Nikki  Mclean
Nikki Mclean
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
