Question about Atari 2600 Console
ON my atari 2600 my paddlel controlers don't work in the left port. but my regular joystick dose. what do i do?
  • 8,596 Answers
Unless you are an electronics expert with a soldering iron, I would just get a replacement paddle from eBay or online seller. I occasionally experienced this problem in the early- to mid-1980s - getting new paddles always did the trick. If you are up for a challenge, look at the joystick pin and then look at the paddle pin - you will see at least a one-pin difference between the two. Check the paddle pin to see if one is physically damaged, then compare the pin on the console itself. Have fun!
-Tha Mp3 Doctor
Posted on Dec 28, 2008
Does the Atari 5200 have the same controller as the Atari 2600?
It does use a slightly different controller. The joystick that comes with the Atari 5200 has 360 degrees of control while the Atari 2600 controler only give you 8 ways of motion. Teh 5200 also has a number pad and buttons for start, pause and reset.
Dec 16, 2013 | Video Game Consoles & Games
Regardless of controller on the left controller port i cant move up
Well it sounds like the controller that you have is not working properly so you could buy a new controller then. Lukie games sells atari 2600 stuff. Or you could open up the controller and try re soldering it the. To see if it works
Apr 29, 2012 | Atari 2600 Console
I was just given an Atari 2600 for Christmas and the controllers do not work. The red trigger button works but the joystick does not, on either side. Is this something that can be corrected or is the...
it has dirty contacts so you unscrew the bottom then put some contact cleaner in it then move the joystick around alot for a good 5 minuets so the cleaner will clean it then the joystick will work
Jan 01, 2011 | Atari 2600 Console
I have an Atari 2600 console. The Player #1 slot is stuck in the firing position. It is not the joystick. I swapped out joysticks and no change. It is something with the console. What can I do to fix this?
Well the controller ports inside of the console might be needed to be resoldered or the controller ports might be broken or it could be just bad controllers then.
Oct 09, 2010 | Atari 2600 Console
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
Paddles don't work for atari 2600
Sounds like a pin has come loose from the main board inside your unit. If you are handy with a soldering iron, and not opposed to opening up your console then, you can take a look at the connection between the connector and the board... If you are not comfortable with this idea, then you can find a competent electronics repair shop on the internet. You could also replace that unit with a "new" one from a number of internet shops or eBay, then retire that one. Hope this helps.
Dec 21, 2008 | Atari 2600 Console
Atari 2600 jr. console + paddle controls = Don´t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Possible Control Port Issue for 2600
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Sep 04, 2008 | Atari 2600 Console
Which Joystick?
YES!
The joystick controllers are backwards compatible with the original 2600 system so you also technically get 2 new 2600 joysticks with this set.
Dec 11, 2007 | Video Game Consoles & Games
Atari 2600 controller problem
I HAVE BEEN REBUILDING ATARI SYSTEMS FOR 20 YEARS AND THOUGHT I HAD SEEN EVERYTHING, AND I WOULD THINK IT TO BE A JOYSTICK PROBLEM. THEY CAN BE REBUILT WITH NEW CONTACTS, BUT I AM THINKING THE PROBLEM MUST BE INTERNAL. I CAN ONLY SUGGEST TRYING ANOTHER DECK. THERE MUST BE SOME PROBLEM WITH THE PINS IN THE PLUG PORT.
IT
Oct 19, 2007 | Atari 2600 Console
Atari 2600 Console Logo
108 people viewed this question
Top Atari Video Game Consoles & Games Experts
Reggie brown
michael galang
EnergeeUK
Level 1 Expert
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
