Question about Zanussi FJS1225W Front Load Washer
Westinghouse 798 front loader 7kg washing machine
Hi, my front loader (westinghouse) is showing an SE error message, can anyone help me? their dad threw out the manual after 2 years of me hiding it! i have 4 kids (3boys) & need it ASAP Thanks all
  • cherylee webster Apr 04, 2007
    sorry that is my 708 westinghouse
  • joeyparko Jun 27, 2008
    yes same as chezars joe
  • 4 Answers
God Sir
I am mr Yapi Antione from abidjan i am dealing with all washing marshing i saw your profle and i am intrested to to know the pris list of all the marshing in your company
i will like to haer from you as soon as posible
yours representetive
Mr Yapi Aantoine
you can reply me in this my email adress
yapiantione@yahoo.com
Or
Call me 0022501307526
Posted on Feb 17, 2008
SOURCE:
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
Front loader LF708C comes up with SE error code, and may run for a minute or so, then stops. This code does not appear in the owner's manual..are you able to help?
Hi, you may find the outlet pipe has a blockage and the system shuts down and stops if the water level does not reduce quickly enough (or the drum may not be turning?.
Hope this helps.
Aug 30, 2011 | Westinghouse Washing Machines
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
7kg 1045 front loader, says SE or 5E wont drain, will open fill and wash but not draining
5E is a water drain error and occurs when the water level frequency does not show changes. First clean the debris filter located at the bottom of the washer and then turn the unit back on after 15 minutes. Please get back to me if you have any other questions.
Kevin
Apr 17, 2011 | Samsung Washing Machines
Error code se on samsung front loader 7kg
could the code be 5e if it is a 5e then the problem would be
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON. Another tech has also done a previous post to this subject so click here to see her repair as well http://www.fixya.com/support/t5093804-se_mean note that if this repair does not work please message me back and there will be other tests for you if this repair she lists does not work if you have any further questions also message me back with them and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Mar 16, 2011 | Samsung WF337AA Front Load Washer
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
My Fisher & Paykel AquaSmart 7kg top loader shows Error Code 245
Error 245: SmartPump Stall
Pump Impeller is jammed cannot turn.
May 24, 2017 | Fisher Washing Machines
LG INTELLOWASHER DD 7KG
You may need to have the door switch replaced but before that should be done, make sure the wire connector is securely in place.
Sep 02, 2008 | LG WM1814CW Front Load Washer
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Aug 03, 2008 | Washing Machines
Zanussi FJS1225W Front Load Washer Logo
521 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
