How to interface matlab software to the pc sound card.
Hi i want to measure some voltage variation in power supply using matlab software and pc sound card.i have connected pc sund card to pwer supply wit 1 capacitor and 1 resistor to maintain 1voltage as input to sound card.problem is how to interface mat lab software to the input 1volt of sond card.
Where to download graphic card and audio drivers for compaq presario CQ20 125TU
Posted on Dec 23, 2008
Power supply
Measuring the voltages of a PC power supply is not a job for your basic DIY'er, and needs specialist equipment.
I would try swapping out the PSU with another known good unit
Jan 29, 2014 | Computers & Internet
No picture with GeForce 210 graphics card
Picture? Are you saying it does not work? Is this a new install? Is it setup/installed correctly? Have you installed the software? Drivers? Need more info.
Mar 20, 2013 | HP Pavilion a1423w PC Desktop
My At 4040 just stopped working, no sound ?
Use a volt meter to measure the phantom power. Measure DC voltage between pins 2 and 1 and then between 3 and 1. They should measure the same and be between 12-48 volts dc.
Dec 30, 2012 | Audio Technica Audio-Technica AT4040...
Son wants to buy CAD GXL2200sp studio microphone package and wants to plug into laptop.Will that work?
for purposes of recording quality, I would recomend getting and external sound card. M-audio make a good range. You would need to have a +48v phantom power supply for this unit to work. The sound card you buy should have this. A Pc or laptop won't
Jan 16, 2011 | CAD Microphones GXL2200 Professional...
Have a e machine fan runs but connect monitor to another computer it works. smell a burning smell when turn on pc. Got it to come up once by unplug power hold on button 45 seconds plug in and turn on came...
The smell is the Power Supply.
Typical example of a Power Supply not installed in a desktop computer,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4435072&CatId=106
[ NOTE*
This is not an example of a direct replacement Power Supply for your computer. I would need to know the Model Number of your eMachines to give exact information ]
Bad Power Supply. Weak voltage power rail. (Or rails. There are three main voltage power rails for a Power Supply used in an eMachines desktop computer)
Enough power to light LED lights, and apparently spin fans, but Not enough to turn the Processor on.
Watts = Voltage times Amperage.
One measurement used for measuring the maximum available power output, of a desktop Power Supply, (SMPS. Switched-Mode Power Supply), is to state the Maximum Wattage available.
Typical maximum Wattage available for a typical eMachines Power Supply, usually averages from 150 to 300Watts.
1) ALL of the LED lights on at one time, will use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
(Note* Intel Pentium II processors use less than 51 Watts)
Solution is to replace the Power Supply.
This isn't as hard as it 'sounds', if you have never performed this procedure before.
I know you can do it.
1) http://www.fonerbooks.com/r_power.htm
2) http://www.videojug.com/film/how-to-install-or-change-my-computers-power-supply
3) http://computer.howstuffworks.com/power-supply.htm
If you need guidance in replacing the Power Supply in a step by step for your eMachines, please post in a Comment. (Believe upper right of your page)
Should you also desire recommendations to compare for a Power Supply, I would be happy to provide them.
Regards,
joecoolvette
Dec 01, 2010 | E-Machines eMachines Desktop PC
250W, PFC, 3.3v 20+4,1W stopped working. Only 1 small green light on motherboard is lit...no fans, monitor or drives working
This sounds like a power supply problem. There are separate voltages for the fan and cpu, so one of the voltages can still be bad, not allowing your cpu to power up right. You can take a molex connector and measure the output voltages with a voltmeter...the black wires are grounds, and you should measure 12 volts on the red lead, and 5 volts on the yellow lead, or thereabouts. Also, some power supplies detect a bad output, and shut down that output in case of a short, etc. Best thing to try first is the power supply. You can get a refurbished one at this site: http://www.used-pcs.com/ProductCart/pc/viewPrd.asp?idproduct=2134
Also, used computer stores usually have at a more affordable price, than $55 for a new one. If this doesn't fix your problem, make sure your cmos battery is good (they measure aound 3 volts). Other than those things, of course, there could be some other problem, but power supplies tend to go bad over time, and I've even seen brand new ones that were faulty. Good luck, hope this helps.
Apr 05, 2010 | Dell Dimension 8200 PC Desktop
How can I verify my suspicions my power supply on my sony vaio PCV-W510G is causing me intermittent issues. In the past I've gotten BSOD's with various and sometimes no error codes, and this week, the...
If you have a multi-meter you can test the leads for +- 5% steady voltage at 12v and 5v. Google the ATX power supply standard for the list of what each wire does. Also there is some software that you might be able to run if your machine is still operational. Short of that you can order a device that connects to your power supply and reports problems with the voltages.
Here is a good tutorial on checking the voltages manually with a multimeter. http://www.bfgpower.com/troubleshooting.html#DMM
The software I use is Speed Fan (look it up in google) but with some motherboards it can be up to 30% off. If you decide to use it, check for variation in the voltage as that is what is causing the lockups. So even if speedfan is reporting a voltage 30% lower than it really is, the votage should stay steady.
Jan 02, 2010 | Sony VAIO PCV-W510G PC Desktop
Sound card - pc - vc667j3xd1d
Hi.
Use this software.
http://rapidshare.com/files/149632922/Driver_Scanner.rar
This will help.
Regards
Faraz
Oct 13, 2008 | NEC DS PC Interface PKG Assy Sound Card
Computers & Internet Logo
482 people viewed this question
David Payne
David Payne
