Back to:
Tags:
Radio Shack Pro-95 Handheld Scanner
Why do I get constant noise on a particular... (by 2 users)
By Bomber - usenet poster
Why do I get constant noise on a particular channel?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Nov 24, 2007
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Horner
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It may be a birdie channel. Birdies are frequencies your scanner uses when it operates. The most common birdies to watch for are listed below. 31.05 MHz 124.20 MHz
41.40 MHz 134.55 MHz
51.75 MHz 144.90 MHz
113.85 MHz
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Why do I get constant noise on a particular channel?:
I don't want to Accept this solution
Solution #2
posted on Dec 23, 2007
Not Rated (0)
71sniper
Rating: 0%, 0 votes
Turn the squelch gradually up till the noise stops. Not for sure it'll work but it's worth a try.
Thank You!
Solution #3
posted on Dec 09, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
The channel may be the control channel of a trunked system. Usuallt the control channel information will show on the display along with the tower being used .
Thank You!
Solution #4
posted on May 27, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
TAKE OFF THE ANTENA IF THE SIGNAL IS STILL THERE AND STRONG ITS A BIRDIE
Thank You!
Can you Help with these Radio Scanners problems?
Radio Scanners
how do i re program if im locked out? please help!
Radio Scanners
how do i get out of lockout mode
When you turn on 0.234.6789 All Channels Locked Out!...
I have a JVC camcorder and I took it to get repaired. It...
The day after Christmas I turned the scanner on and it...
Loading problems.
Repair Service
Find Radio Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
