Question about Sony Playstation 3 (PS3) Console
I need help :(
Hi i need some serious help i dont have wire-less connection i have the cable and i got everything down but now it keeps saying i have a DNS error i try to change it but no dice plzzzzzzzzzzz help me!!!!
Must contact you IP Service provider for the the DNS Number and input the DNS adress for it to work.
Posted on Dec 21, 2008
I have a 1979 Corvette. The Alternator Exciter will not turn off. This keeps the generator light on even after shut down(key removed). Any suggestions?
I would say that your wiring loom leading to the alternator could be shorting out either with moisture or by explosed metal of the cable through the car's metal work, It would be worth it if you are skilled in the use of electrical testing equipment (DMM)to follow continuity of resistance along the wires, although this will require having to make breaks in the cable or un attaching established connections, And/Or looking for obvious damage (frayed cables etc.) if you dont know what your doing then its much better to get somebody who does,
Hope this helps, Sion.
Aug 25, 2011 | 1972 Chevrolet Corvette
Hi i have an ethernet cable to my hub from my wii
you probally selected wireless connection instead of wired connection
hope this works,
Luke Wilcox
Dec 29, 2009 | Nintendo Wii Console
My internet keeps dro, i have installed filters ,
There is one case where everything is fine but still connection drops too often.---
This happens when the network type of your laptop is "public" as ublic networks are less secure, routers usually drop connections after sme time. Change the network type to "private". This should solve your problem. There is one more setting in your router where is says something like "automatically login when disconnected". Selecting this option allows automatically login to ISP when connection is dropped from ISP temporarily.
If network connectivity itself is the problem then you can debug followingly.
Step-1:
If ISP company says everything is fine from their side, then you need to check your router. To confirm this first connect the wall outlet of ISP to your laptop and check network connectivity. If there is problem, then ISP has to fix it.
Step-2:
If connection works fine then ISP is fine and you need to check your router settings. Now check network connectivity by connecting the laptop to the router through a ethernet wire. If the network does not work then your router hardware could be wrong and may need servicing or replacement. If this works fine then go to step-3.
Step-3:
Try resetting your router by using a paperclip. Usually the reset button can be found at the backside of your router. This will reset all the settings and there by making as good as a fresh one. Try to access internet from a place close to router where router signal is strong.
Change authentication and other network settings of your router to connect to ISP. Now network should work fine. Ensure that you set router password to avoid unauthorized access to your router by others.
Nov 08, 2009 | D-Link Computers & Internet
My new ipod pink nano 8gb keeps freezing
First you have a bad port on computer you probably need to plug your cable in the back of the computer. If you keep letting your ipod freeze like that your going to seriously mess it up. I'm going to teach you a way to fix your problem with freezing. the next time your ipod freezes hold the "MENU" and "CENTER" button at the same time. After that you need to take your ipod and restore it through iTunes. Please rate this response I would like to know if I helped.
Apr 13, 2009 | Global Baby Once Upon A Dream Musical...
I have a 2 wire for my home computers, I have two laptops one is a Dell and the other one is a Toshiba, but I don't have wire less connection on either one, I am computer illiterate, can you help me?
Hi!
You can connect them together via an ethernet cable, but that cable needs to be an cat 5 crosstalk cable.
Good luck
Please take a moment and rate my help for you
Nic
Feb 21, 2009 | Computers & Internet
Cannot finish connecting
Hi fozzy211 - Please don't rate this 'til were finished. You've got two things going on. You said it's telling you to check the cables and then you say it's saying the router isn't from Verizon. Is it both? Are the cables hooked up correctly to your knowledge? We can fool Verizon's system. Let me know if you actually have two problems. For now I would only hook up one pc via wired until it's working. I'll await your response. Thanks.
Jeff
Jun 04, 2008 | NetGear WGR614 Wireless Router
Limited or no connectivity
Hi, I had the limited or no connectivity problem on my wifes laptop for about a year.
THE SOLUTION:
Go into your wireless router/transmitter and change the channel. eg. mine was on Channel 10, and the following all connected Acer Laptop, Xbox360, Wii, Blackberry but not the Vaio. I changed to Channel 4 an the Vaio sprung into action and everything else updated itself automatically.
Dec 05, 2007 | Sony VAIO GRT260 Notebook
Connecting router into a several computers
if u r going to connect ur pc through wired no need to install any thing>run a cable from pc to the ether net jack on the cisco router and it will start working>u need to use rj-45 cables>
if u r going to use pc's through wire less then u need to login to ur router and change the SSID name as ur wish and enable the ssid broadcast>and change the channel 1 or 11>and save that >and restart the wire less pc's>and in the pc right side down corner u can see wire less i-con>click that and click on view avaliable net works>and search for the SSID that u changed in the router screen and click on connect rate me solved if its help thx
Nov 11, 2007 | Cisco (WS-X3011) Router
Sony Playstation 3 (PS3) Console Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
