Question about Kogi L7CH Monitor
Monitor sounds? I turn my computer and monitor off at 2 in the morning and the monitor is making these noises as if it's cooling down. Sort of like when you grip it and it makes that cracking/popping sound. I can understand if it makes that sound right away because it's cooling off, but it's 4:50 in the morning now and I just woke up because it made that noise again several times in a row. Does this happen for anyone else or is my house just haunted?
  • Edward Lee Apr 05, 2007
    Thanks dude, that helps a lot. I was starting to freak out. And it's been happening for a good couple of months now...luckily nothing has burnt out. But I mean..would it still do that, like two hours after I turn it off? That's the part that wakes me up in the middle of the night.
    Alright, thanks Berwin
    Problem Solver:
  • 12 Answers
It happened that to me last year. After 2 weeks of cracking sound symptoms, my monitor begun to blackout - no video signal but the indicator light is still available. I checked it inside using my tester, one of its transistor was burned-out. I tried to replace it and its working up to now. Possible cause of this is probably overuse of monitor without proper ventilation causing electronic components to overheat. Try to bring it to an authorized TV repair man in your local area for proper diagnosis - Don't try to fix it yourself. He's the right expert to that.
Posted on Apr 04, 2007
  • Erwin Bernard Talento
    Erwin Bernard Talento Apr 05, 2007
    Do you mean a continuing noise from the monitor even after you pull the main plug?
    If there's a probable components defect inside, it will manifest its symptoms if there's an electric power present. It should not make a cracking/popping sound if the monitor is unplug from the outlet or UPS/AVR or computer. Try to disconnect its power line and notice if it's still making noise.
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
Screen is black. Blue light flashes intermittently. Makes clicking sound when it flashes. Rebooting computer doesn't help. Unplugging and re-plugging in monitor doesn't help. Disconnecting and...
is the monitor making the clicking noise or your computer
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 17, 2011 | ViewSonic VX1935wm LCD Monitor
I have the VGC-VA10G, and one morning I turned it on and the monitor wouldn't turn on? The pc runs perfectly fine. It's just, everytime I try to turn the monitor on, it makes 2 clicking noises and doesn't...
check ur memory card remove the memory card and restart ur computer with out the memory id u hear beeps clean the contacts with an erasor and wipe it clean with a clean cloth and insert it int the slot after shutting down the computer
Oct 17, 2010 | Sony VAIO VGC-VA10G (027242685789) PC...
My monitor is making a electronic noise
u have a problem with electornic circules
Nov 04, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor doesn´t work
1 MAKE SURE THE DATA CABLE IS CONNECTED TO THE CPU.
2 MAKE SURE TO TURN THE MONITOR ON.
Aug 05, 2009 | Samsung SYNCMASTER 943B 19" LCD Monitor
Faulty LCD Monitor ?
off hand it sounds like a power supply issue. sometimes fixable sometimes not.
Robert
Aug 26, 2008 | Scanport Computers & Internet
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
Computer making noise
Monitor clicks, pops, or makes other noises. Issue: Monitor clicks, pops, or makes other noises.
Cause: This issue could be caused by any of the below possibilities:
  1. Monitor degaussing.
  2. Monitor changing resolution.
  3. Monitor syncing with the video card.
  4. Monitor warming up.
Solution: Noise when turned on or off It is normal for standard computer CRT monitors to make a click, pop, crackle, hum, buzz, or other type of noises when they are first turned on or turned off.
Noise when monitor goes into standby mode When the monitor enters a "standby mode" or "power savings mode" this is similar to the monitor being turned off. It is completely normal for the monitor to make a noise when the monitor enters this mode.
Noise when opening Microsoft Windows or other operating system or when opening a game When a computer opens its operating system, for example, a computer opening Microsoft Windows or when a user runs a computer game it is very common that the monitor will need to switch its resolution of the operating system or game. When switching resolutions it is normal for the computer monitor to make some type of noise and/or for the computer monitor to flick or flash.
Noise during normal operation If the computer monitor click, pops, or flashes while it is being used this is not normal operation. It is very likely that the monitor may be failing or a component within the monitor has already failed and could also potentially be a fire hazard. We highly recommend that the monitor be repaired, replaced, and/or looked at by a qualified technician.
Additional information:
  • See document CH000302 for additional information and other noises that may come from
Jan 16, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
I have to heat up my CRT
it is a weak cathode heater inside the CRT. One fix, besides what you are doing, is to replace the glass tube (crt) inside the monitor. Unless you can find a used one, may be hard to find now. It may also be possible to supply the heater filament with a separate supply. I believe this requires a 6 volt supply, so try adding a 10 volt (FUSED- 2 amp) supply to the filament only.
Nov 20, 2007 | Computers & Internet
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
Kogi L7CH Monitor Logo
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
