Question about Sony 256MB Classic Violet Micro Vault USB 2.0 Flash Drive with Virtual Expander 256 MB USB Portable (USM256EVVFT) Drive
Inability to show media files such as mpeg,jpeg&also audio files
After copying some of the named files above they either don,t open up or demand for plug ins or either say they are not supportted,the audio&video files get changed into an unrecognized format,i.e(small squares form)
Try to format the drive!
Posted on Aug 08, 2007
SOURCE:
Can I transfer my iPod photos to my ps3 system? If so how? Ive done clicked on every thing tryin to figure it out so, before I give up, can any one pleeease help :)
There are many ways in which you can put media onto your PS3, and although this is not a definitive guide on every single possible way, I will outline the most common ways one may put media onto your ps3!
*NOTE*
Im using the new Firmware, 1.90. I suggest you upgrade as well for maximum flexibility, and for consistency in this article.
I think that before showing you how to put media onto your PS3, you need to know what kind of files it will play, as only certain files can be played!
Pictures:
-JPEG (DCF 2.0/Exif 2.21 compliant)
-TIFF
-BMP
-GIF
-PNG
Music:
-Memory Stick Audio Format(ATRAC)
-MP3(MPEG-1/2 Audio Layer 3)
-MP4(MPEG-4 AAC)
-WAVE(Linear PCM)
*NOTE ON MUSIC*
If you have licenced MP3s, or any other kind of restricted material, then it most likely not play using the PS3s music software.
Video:
-Memory Stick Video Format
-MPEG-4 SP (AAC LC)
-H.264/MPEG-4 AVC Main Profile (AAC LC)
-MPEG-1 (MPEG Audio Layer 2)
-MPEG-2 PS (MPEG2 Audio Layer 2, AAC LC, AC3(Dolby Digital), LPCM)
-MPEG-2 TS (MPEG2 Audio Layer 2)
Copy using Device
Now that you know what kind of files the PS3 will play, it is safe to put them onto the PS3s HDD!
Transfering using a CD(Using Files), Memory Stick, Flash Drive(USB), SD Card External HDD*, iPod*, which will all be referred to as 'device':
It is important to know that you must(well, not sure if its a MUST, but it works better this way) have folder corresponding to what media you are transfering. For example, im going to transfer two songs, two pics, and two videos. So, on the device im using, I would make three different folders: Music, Pictures, Video. Understand? Great.
Now, once you have copied the media(files), and placed them into their corresponding folders, you can insert the device into the PS3. Switching to the PS3s OS(operating system), you can copy the media to your ps3 pretty easily, and its the same for pictures, music, and video. For my example I will use an SD Card as the device used to copy media:
Using anything but an external HDD or iPod:
1. Using the PS3 controller, find the appropriate tab (Music, Video, Photo).
2. Press the Down key until the device is shown. My device is a SD Card, so I will highlight it.
3. Press the triangle Button once it is highlighted, and select display all.
4. Press the X Button on the corresponding folder(Video for Videos, etc).
5. If copying more than 1 file, press the triangle button and press the up arrow on the controller until you highlight the 'Copy Multiple.' Press X. Now you can choose which media you wish to copy, or you can copy everything by pressing the right arrow, and choosing 'Select All' then Ok.
6. Watch as your media is copied to the PS3!
Using an iPod:
1. Locate the white USB cord that came with your iPod. In case you were wondering, thats also probably how you charge your iPod too. smile.gif
2. Connect the iPod to the PS3 using the USB Cord. Yes, you can do this.
3. Highlight the iPod using the controller, press Triangle. Then highlight display all and hit X.
4. Select iPod Control, Select the appropriate folder (music, Video, Pics), Hit X.
5. Hit the Triangle Button again, and select copy multiple. See step 5 above.
Using an HDD:
Ok, I admit, Ive never used an external HDD to copy anything to my PS3. But if you have read the steps above, I can almost guarantee you will have to hit Triangle, Display All, and then find where you put the stuff. Its important to be organized, so you should probably just have a folder that contains all music, all video, and all pics, broken down however way you like it. The steps to copy the media should all be the same as above. smile.gif
Copy using "Search for Media Servers"
Ok, this is a bit more complicated. The only way I know how to do this is using windows, so for everyone using linux, "Lawl." Im sure there are more ways to do this, im just showing you the way I figured it out. You *MUST* have a router to do this, or be on the same network as your PS3.
For demonstration purposes, I will use music for my example. This will also work with pictures and video
1. Transfer all media to the My Documents folder, and put them into the correct folders.
2. Load up PS3.
3. Goto Windows Media Player 11(If you dont have it, DL it), Library, then Media Sharing. Select "Unknown Device" and hit allow. **DO NOT** 'Allow new devices and computers automatically.' This will let any computer connect to yours, and probably will allow them to upload some nasty Virus'
4. Go back to your PS3, and now under Video, Music, or Picture tab and now select the thing with the Windows Icon. *Note: if there are more than one, then select the computer you want to retrieve your media from, ie yours.
5. Select Music. Hit X. Hit down until you highlight Folders, hit X. Goto my Music. If you wish to copy the whole folder, hit triangle and select copy multiple, the select all and copy. If you wish to only copy a few songs, select the My Music folder, hit x, then triangle, then highlight the song and hit copy.
Jul 06, 2011 | Computers & Internet
Tip
How to do Blu-ray playback using Media Player Classic Homecinema
Media Player Classic Home Cinema is an extremely light-weight free program for Windows. It looks just like Windows Media Player v6.4, but has much more additional features. You can use it as a Media Player Classic Home Theater. MPC Homecinema supports a wide range of decoding formats and file formats, following are the details:
Supported Decoding:
MPEG-1, MPEG-2 and MPEG-4 playback. Media Player Classic is capable of VCD, SVCD and DVD playback, without the need to install any additional software or codecs.
It has built-in codecs for MPEG-2 video and codecs for LPCM, MP2, AC3 and DTS audio, and also contains an improved MPEG splitter that supports playback of VCDs and SVCDs using its VCD/SVCD/XCD Reader. A *.mp4 and MPEG-4 Timed Text support added. An AAC decoding filter makes MPC suitable for AAC playback in MP4.
MPC Home Cinema also has H.264 and VC-1 with DXVA support, DivX, Xvid, and Flash Video formats is available in MPC HC. MPC can also use the QuickTime and the RealPlayer architectures. Media Player Classic supports native playback of OGM and Matroska container formats.
Supported Video, Audio and Image File Formats:
WAV, WMA, MP3, OGG, SND, AU, AIF, AIFC, AIFF, MIDI, MPEG, MPG, MP2, VOB, AC3, DTS, ASX, M3U, PLS, WAX, ASF, WM, WMA, WMV, AVI, CDA, JPEG, JPG, GIF, PNG, BMP, D2V, MP4, SWF, MOV, QT, FLV
To make commercial Blu-ray movies playable with Media Player Classic Homecinema, one thing you have to do is using a blu ray disc ripper to remove copy protections before your playback. The following contents will give you the detailed steps.
Note:
If you are using a powerful PC, you can do the following "Directly Copy". When playback, MP Classic Homecinema will automatically download codecs as needed, so you are able to successfully play m2ts files directly copied from the BD disc, which have the same quality as the original.
1. Load Blu-ray files to Pavtube Blu-Ray Ripper
Three ways are available – "BD/DVD ROM", "BD/DVD Folder", and "IFO/ISO".
2. Select output format
Click on the dropdown list at the end of "Format", then follow "Copy">"Directly Copy".
Note:
If you are using a slower PC, we suggest you not to select "Directly Copy", because your slower PC will attempt to play the output m2ts files, but the sound does not keep up. So other formats supported by Media Player Classic Homecinema are recommended. To remain the high quality of a Blu-ray movie, you can choose "HD Video" as output format as below:
3. Click "Settings" button to adjust audio and video parameters
Note that this option is unavailable if you are using "Directly Copy". Generally speaking, the default settings are able to satisfy your needs basically, but if you have higher expectations of the output files, you can adjust all the following video and audio parameters according to your own requirements.
4. Click "Convert" button to start Blu-ray ripping
As soon as the ripping work is finished, you can get the output files for MPC Homecinema via tapping "Open" button. After that, you can import the files to MPC HC for playback. Have fun.
Additional Tips:
More than "Directly Copy" and format conversion, Pavtube Blu-Ray Ripper also supports "Full Disk Copy", which enables you to get a standard Blu-ray structure ready for burning.
on Apr 20, 2010 | Audio Players & Recorders
I CAN NOT PLAY MUSIC USING MY MEDIA PLAY
windows media does not support all extensions. Below are the examples. if you have the right format and still you are not able to play then best option is to upgrade or reinstall media player. Windows Media Player 6.0 loadTOCNode(2, 'moreinformation');
  • Windows Media formats
    File name extensions: .asf, .asx, .avi, .wav, .wma, .wax, .wm, .wmv, .wvx
  • RealAudio and RealVideo (version 4.0 or earlier)
    File name extensions: .ra, .ram, .rm, .rmm
  • Moving Pictures Experts Group (MPEG)
    File name extensions: .mpg, .mpeg, .m1v, .mp2, .mpa, .mpe
    Note MPEG 2 requires third-party software or hardware decoders.
  • Musical Instrument Digital Interface (MIDI)
    File name extensions: .mid, .rmi
  • Apple QuickTime (version 2.0 or earlier)
    File name extensions: .mov
  • Macintosh AIFF Resource
    File name extensions: .aif, .aifc, .aiff
  • Intel Video File
    File name extensions: .ivf
  • UNIX
    File name extensions: .au, .snd
Windows Media Player 6.1, 6.2, 6.4, 7, 7.1, Windows Media Player for Windows XP, and Windows Media Player 9 Series loadTOCNode(2, 'moreinformation');
    File name extensions: .asf, .asx, .avi, .wav, .wax, .wma, .wm
  • Audio Visual Interleave
    File name extension: .avi
    File name extensions: m3u, mp2v, .mpg, .mpeg, .m1v, .mp2, .mp3, .m3u, .mpa, .mpe, mpv2
  • DVD Video
    File name extension: .vob
    Note DVD playback requires third-party software or hardware decoders and is supported only in Windows XP.
    File name extensions: .mid, midi, .rmi
  • Apple Macintosh AIFF Resource
  • Sun Microsystems and NeXT
  • Intel Video File
    Note Intel Video File support requires the Intel Video 5.x codec.
  • Windows Media Player Skins
    File name extensions: .wmz, .wms
  • QuickTime Content
    File name extensions: .avi, .mov, .qt
    Note Windows Media Player can play back older forms of the QuickTime format only. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/316992/EN-US/ ) Windows Media Player Multimedia File Formats
  • Algebraic-Code-Excited Linear Prediction
  • UNIX
  • Macromedia Flash
    File name extension: .swf
Dec 10, 2010 | Gateway M350CS PC Notebook
How to put movies on ps3 harddrive?
Hi skillet3716,
Format a USB drive as FAT32 file system (NTFS will not work with PS3), create a folder called "VIDEO" (without "s), put the video in there.
name new folders "PICTURE" and "MUSIC" for those types of files as well.
The PS3 will also allow you to access a variety of media file formats from the video, music and photo menus of the Cross Media Bar.
VIDEO
# MPEG-1
# MPEG-2 (PS,TS)
# H.264/MEPG-4 AVC
# MPEG-4 SP
MUSIC
# ATRAC (.oma .msa .aa3)
# AAC (.3gp .mp4)
# MP3 (.mp3)
# WAV (.wav)
IMAGES
# JPEG
# GIF
# PNG
# TIFF
# BMP
Regards
R.K.
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
What format should I name my files?
I have found that videos need to be in MPEG 4 and photos JPEG
Sep 27, 2009 | Insignia Pilot MP3 Player
Trying to use movies saved in flipshare in movie maker want to save the flipshare files as mpeg, flipshare is saving them as jpeg How do I save the videos in flipshare as mpeg...why are they saving as...
Flip video camcorder has made its name world wide. It's very creative, cool and super simple. You can email videos (it will automatically compress and reformat the video to an acceptable size), save videos locally (you can organize them by creating folders), share videos online via AOL and edit them as well. It also has very simple yet functional video editing capacity; the four family members Flip Mino, Flip Mino HD, Flip Ultra and Flip Ultra HD will definitely meet demands of a large quantity of population with different preference.
At the time we are happy for ourselves for having purchased it to make some memorable videos that we can share in a blink of the eye with our friends and family. We find there is something flip video just can’t do, flip video produces h.264 and mp4 files. But some one would prefer the. Mpeg file as output format. Is there a shortcut to convert flip to mpeg?
Flip video to mpeg converter is a very powerful and easy-to-use Flip Video to mpeg video converter app. It can convert any Flip video to mpeg with flexible settings and high conversion speed. The program supports Flip Mino, Flip Mino HD, Flip Ultra and Flip Ultra HD. Flip video to mpeg converter allows you to convert multiple video files at a time, trim your video files to capture your favorite video clips, crop movie video, and set movie effects and so on.
Jun 04, 2009 | Pure Digital Flip Video Ultra Camcorder
Trying to put I-DVD movie on my digital photo frame
Re-edit the movies and pictures following the formats below: Video:
File Format: MOV
Video Compression: MPEG-4 ASP, MJPEG
Audio Compression: MP3, G.711, PCM, ADPCM, 8-bit linear
File Format: AVI
File Format: MPG / MPEG
Video Compression: MPEG-1
Audio Compression: MPEG audio Picture:
File Format: JPG / JPEG
Video Compression: Baseline JPEG
Music:
File Format: MP3
Video Compression: PCM, ADPCM, MPEG 1 layer 1,2,3
Apr 02, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How do i get my video to play....i am following the directions in the book....when i hit play...i get nothing....i am frustrated ....could someone let me know the step by step directions to get the video...
Make sure that you have the correct video format and compression. Video:
File Format: MOV
File Format: AVI
Music:
File Format: MP3
You will need to re-edit the video files you have for the frame to recognize it.
Feb 21, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I tryed putting a video on my psp and it didnt pop up in the videos but took up 400 mega bites of memory i cant get it off
You can play files of the following types on the PSP system.
  • Memory Stick Video Format
  • - MPEG-4 Simple Profile (AAC)
  • - H.264/MPEG-4 AVC Main Profile (CABAC) (AAC) and Baseline Profile (AAC)
  • MP4
  • AVI
  • - Motion JPEG (Linear PCM)
  • - Motion JPEG (μ-Law)
Copying a file manually Copy the video file to Memory Stick Duo media to enable it to be played on the PSP system. Using a PC, create a folder named "VIDEO" within the Memory Stick Duo media, and then copy the file into that folder.
Jul 07, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
76 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
