Question about Whirlpool LER4634J Electric Dryer
Switch does not turn on.
When I press the switch to turn it on it does not turn the dryer on. You can hear the timer working on the timed dial but can not turn it on.
  • rdshiloh Jan 15, 2009
    I have the same problem whirlpool ler7646eq1. Any suggestions?
  • 979 Answers
I believe this to be the motor is burned out or hopefully a wire is loose or burned in two. Make sure the breakers are reset and the connections are tight in the back.
Posted on Jan 14, 2009
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
20 seconds. The red indicator light will go off and any previous
light will start flashing.
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
light will go off.
Rotate the time dial clockwise to the first desired ON time.
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
I have a Frigidaire dryer model FDE437GHS0 It has been working fine til this morning. If I turn the timer switch to time dry and push the start button it sounds like the timer is turning(or the gears are)...
IT SOUNDS LIKE THE TIMER IS BAD. IF THE TIMER MAKES NOISE IN ANY POSITION AND GRINDS THE LITTLE TIMER MOTOR OR THE TEETH ON THE MAIN GEAR IS SLIPPING
Aug 11, 2009 | Dryers
Starts automatically when I set the timer
This could be a problem with the start button switch (it should click when pressed/released) or with the switch on the motor.
May 20, 2009 | Dryers
I have a 5 year old Whirlpool Electric Dryer, Model #LER7648KT2. The Dryer won't start. I have checked the door switch, start button switch and visible thermo switches or thermostats with an ohm meter...
There are usually 2 thermal fuses in dryer circuits. One is on the heater housing and will blow in an overtemp condition around 310-350F.
The other is on the blower or exhaust housing and will blow around 200F
Make absolutely sure the 2nd one is continuous and not intermittently functional. This will definitely stop the motor from functioning
Below is a diagram for an older model (LER4634). Your dryer has some additional terminals probably because it has additional drying cycle options.
The diagram may be more readable when copied and pasted into a plain text editor such as Notepad or another editor with non-proportional fonts
Switch Terminals
|TM |TM |BK |BK |BK |
|WB |OR |BU |BU |R |
|-- |-- |V |-- |-- |
|O |X |O |X |X |Auto - High Heat
|O |X |X |X |X |Auto - Low Heat
|<> |<> |~ |X |O |Cool Down / Fluff
|O |X |O |O |O |End of Cycle
|X |O |O |X |X |Timed - High Heat
|X |O |X |X |X |Timed - Low Heat
Legend:
O = Open (Infinite Resistance)
X = Closed (Continuous)
<> = Either (But not Both)
~ = Doesn't Matter
NA = Not Applicable
Switch Terminals:
TM - Timer Motor (Different Models may use different colors)
WB - Black/White
OR - Orange
BK - Black
BU - Blue
V - Violet/Purple
R - Red
Example: For the Auto - High Heat Dry cycle, the following terminals are continuous:
Terminals
<TM - OR>
<BK - BU>
<BK - R>
(of course since BK-BU is continuous and BK-R is continuous, then BU-R is also continuous.
This should allow you to test at least some of the cycles your timer switch has
I have a general schematic in PDF for whirlpool for gas and electric, but did not see an option to add an attachment to this message.
Hope this helps or point you in the right direction.
Apr 21, 2009 | Dryers
Whirlpool LER4634J Electric Dryer Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
