Question about Sansui RZ-8150AV Receiver
Volume Knob (Sansui RZ9400)
I have a RZ9400, the problem is that i can't turn a volume up using the Volume knob, I can only turn it down. only a remote control is able to do this. The remote control can turn up or down the volume. can anyone tell me if this is normal? i've trying to track-down for people who have this type of receiver, but it seems like no one have it!
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
Posted on Nov 13, 2007
  • 236 Answers
SOURCE: Sansui tv/vcr combo is stuck on highest volume.
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
Posted on Feb 19, 2008
  • 476 Answers
SOURCE: Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
Posted on May 08, 2008
SOURCE: The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
Posted on May 10, 2009
  • 349 Answers
SOURCE: my remote control stopped working
Can you let me know if you still have this remote control. Mine has buttons busted too but if you cant use yours...can I have it please for parts?
This Tv is not up to much by todays standards anyway and most people are just chucking them out now.
What will you do with yours I wonder?
Pls email me at I am at Logan south of Brisbane.
Regards tminbox
Posted on Oct 19, 2009
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Is it KDG200 or KDG116?
In KDG200, press and hold SEL to display menu
Turn volume knob or press fwd or rev buttons to select CLOCK H and set.
Press Volume knob to save.
In KDG116, instead of turning the volume knob, use +/-. Instead of pressing the Volume knob use SEL
Mar 01, 2012 | JVC KD-G200 CD Player
How do I turn off the demo mode in my jvc kd-hdr44 radio deck?
Press and hold MENU. Turn volume knob to select group, press volume knob to select item, turn volume knob to select, and then press volume knob to save.
Mar 01, 2012 | JVC Car Audio & Video
How to set digital clock on ix35 Hyundai highlander
Turn the radio on.
Hold down the volume knob for 3 seconds.
The display will come up Volume Setting
Rotate the volume know clockwise until the display switches to time setting.
Push the volume knob.
Rotate the volume knob to select the hour
Push the knob
Rotate the volume knob to select the minute.
Push the knob.
Nov 30, 2010 | Car Audio & Video
The Volume knob malfunctions
Hi there. Sorry I haven't got a solution. Just want to know if you found one, as I got the very same prob with the volume knob of my JVC hi fi. Thanks for your time.
Oct 05, 2009 | JVC MX-J30 CD Shelf System
Volume knob broken
needle nose pliers to turn it down,find another knob there pretty common even if you had to use a drop of super glue.
Aug 29, 2009 | Sony TA-N9000ES 5-Channel Amplifier
Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Jan 06, 2009 | Yamaha RX-V800 Receiver
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
