Question about Toshiba MD13P1 13" TV/DVD Combo
Unknown Fuse Do you know what fuse a Toshiba MD13P1 TV/DVD combo uses? I took out a blown one from my TV but lost and don't remember what kind to replace it with.
5 Suggested Answers
  • 8457 Answers
SOURCE: Toshiba MV13L2 13 in. TV/VCR Combo
It could be any fuse it fit the right size the gap of the fuse.
A fuse just gap to board transfer electricity.
Posted on Aug 13, 2009
micromatikal
  • 2777 Answers
SOURCE: Hi Guys, I have
Strange, I am researching this now, it just keeps blowing that fuse over and over?
Thanks please confirm
Tim
Posted on Oct 06, 2010
bobbellaire
SOURCE: I have a toshiba tv/dvd combo. After finishing the dvd I can't get back to the tv. Don't know which button I need to use. Can you help?n
use the input button and go to tv/antenna
Posted on Nov 21, 2012
lpfaff1
  • 11573 Answers
SOURCE: Toshiba tv fuse blown
Sharon, if 2nd. fuse blew , there is a short in power supply probably.
When changing fuses try always to change with same type amps. and volts as original.
Posted on Feb 28, 2016
Our toshiba mw20f52 tv/vcr/dvd won't turn on. It worked fine last night. Is it fixable or dead? Should we try anything in particular to "jump" it? And there are a dvd and a vhs still in it! ...
You may have blown a fuse in which case something else inside is probably shorted. Check diodes and transistors near the blown fuse if you know how. If you're not comfortable working on electronics I would check the phonebook for a hometown TV repair shop. They may be nice enough to retrieve your movies for you at a minimal charge and maybe give an idea of how much to fix the set. Good luck.
Apr 28, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
Tv power button doesn't work, don't have remote, can't know if tv works when plugged in
remove the back panel and inspect the power supply, check for blown fuse then the board for any blown or bulged capacitors and any black spots on the board.
Dec 14, 2010 | Toshiba 26LV47 26 in. LCD TV/DVD Combo
Need code for Phillips Universal romote control for Toshiba 2003 13" with dvd player pls.
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
Nov 13, 2009 | Toshiba MD13P1 13" TV/DVD Combo
My tv toshiba md13p1 combo tv is not working. when i plug in makes a noise like a bee buzz. the only way to turned off is to unpluged.how much it cost to repair?
That buzz sound most probably are from axed horizontal output transistor. If your tv is a CRT type. Some other reason for that are faulty regulator, and diode on flyback side, or the expensive one is the flyback itself.
If age is the reason transistor can be replaced as soon maybe thirty minutes. Please get a quote and estimate first to calculate if new tv is more ideal than having it repaired.
Oct 05, 2009 | Toshiba MD13P1 13 in. TV/DVD Combo
it should tell you on the board where you took it out of it usually around 125v/4amp
Feb 02, 2009 | Toshiba MV13L2 13 in. TV/VCR Combo
Toshiba MD13P1 13 in. TV/DVD Combo will not turn on
PROBABLY THE NOISE YOU ARE HEARING IS LIKE YOU SAID A BURNT FUSE OR THE RESISTANCE OF THE T.V. AND USUALLY REPAIR FOR THIS ITEM WILL COST YOU MORE THAT REPLACING THE TELEVISION SPECIALLY WITH A DVD INTEGRATED, BECAUSE THEY ARE WIRED TOGETHER. GOOD LUCK.
Oct 02, 2008 | Toshiba MD13P1 13 in. TV/DVD Combo
Lost Remote
You need the instrution paper that comes with the remote. If you lost that paper you can not set up the remote.
Artgirl
Jul 08, 2008 | Toshiba MD13P1 13 in. TV/DVD Combo
Toshiba md13p1
You can buy a remote for less than $20 online. Google remote control # DC-FN20S & you'll find it.
Nov 06, 2007 | Toshiba MD13P1 13 in. TV/DVD Combo
Language screen won't go away
It seems you need to buy a new remote ,here is all the inf.you need.http://www.remotes.com/remotes/servlet/rs?uid=A1158853432594&o=c&a=Search&o=c&m=md13p1
Sep 04, 2006 | Toshiba MD13P1 13 in. TV/DVD Combo
Toshiba MD13P1 13" TV/DVD Combo Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
