Question about ASUS P5GD1-VM Motherboard
Setup did not find any hard disk drive on your computer
I'm running Windows xp and my computer has been giving me problems so i decided to format my HDD. But "Setup did not find any hard disk drive on your computer". Even though XP is running and HDD is working fine.
Asus P5GD1-VM
I need the PATA driver
HDD: WDC WD25 00JB-00GVC0 SCSI
  • aoapowers Feb 09, 2009
    i was have this proplem but i solve it
Is it a SATA hard drive or an IDE drive, depends on configuration but will not recognise HD if it is not configured, you will probably see on boot up, IDE not found probably running a SATA drive
Posted on Jul 07, 2009
U most insert a flopy disk with ite 8211 and press f 6 whil windows starting instllation
Posted on May 14, 2009
Just look for the BIOS set up and I,m sure you will solve your problem, or plug the IDE cable properly...
Posted on Dec 21, 2008
INSTALLED ILLEGAL WINDOWS 7 AND WANT TO GET A LEGAL VERSION OF XP BACK
Hope this would be helpful. Kindly follow the instructions.
Prepare the hard disk according to the manufacturer's instructionsIf you are using a SATA hard disk, skip this step and go to the "Determine the type of file system that you want to use" section. If you are using an IDE hard disk, set the jumpers and the cabling according to the role of the hard disk (for example, master or subordinate) and make any required BIOS (or CMOS) changes. To set the jumpers and cabling, and make any required BIOS or CMOS changes, see the documentation that was included with your hard disk and motherboard, or contact the manufacturers.Determine the type of file system that you want to useYou can use either the NTFS or FAT file systems. NTFS is the preferred file system to format the hard disk unless you want to run an earlier version of Windows that cannot read NTFS partitions. For additional information about the differences between the FAT and NTFS file systems, click the following article numbers to view the articles in the Microsoft Knowledge Base: 100108 Overview of FAT, HPFS, and NTFS file systems 310525 Description of the FAT32 file system in Windows XP If the hard disk already contains data, back it upMake sure that you back up all your important data before you continue. When you partition and format a hard disk, all the data on that partition is permanently deleted. You can view current partition information without deleting your data. For additional information about how to use the backup utility or the Files and Settings Transfer Wizard, click the following article numbers to view the articles in the Microsoft Knowledge Base: 320820 How to use the Backup utility to back up files and folders in Windows XP Home Edition 309340 How to use Backup to restore files and folders on your computer in Windows XP 293118 How to use the Files and Settings Transfer Wizard 306186 How to use the Files and Settings Transfer Wizard from CD-ROM 306187 How to use the Files and Settings Transfer Wizard Disk in Windows XP If the hard disk has a drive overlay or a disk management program, make sure that it is compatibleIf your computer uses drive overlay software for large hard disk support, do not use the Windows XP Setup program to partition or to format the drive until you have verified that Windows XP is compatible with the software. If you have drive overlay software installed, contact the software manufacturer to find out whether it is compatible with Windows XP. If you are not sure whether you have drive overlay software installed, contact the manufacturer of your hard disk drive or motherboard.If you have software that you want to reinstall, verify that you have the disksMake sure that you have the original CDs or floppy disks so that you can reinstall the software programs after you partition and format your drive. If you purchased an upgrade for a program, make sure that you have the full version of the original program. Many upgrades for programs require a compliance check before you can install the upgraded product. If you cannot find the original CDs or floppy disks, contact the software manufacturer before you continue.If you have updated device drivers for peripheral devices, back them upIf you have installed an updated device driver for your peripheral devices (for example, modems and printers), make sure that you back up the new driver for the device to a location other than the drive that you want to format and partition so that you can reinstall it after you install your operating system.Configure your computer to start from the CD or DVD drive To start your computer from the Windows XP CD, your computer must be configured to start from the CD or DVD drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD or DVD drive, see the documentation that is included with your computer, or contact the computer manufacturer.
If you have a computer that cannot start from the CD or DVD drive and you need to start your computer from the startup disk, make sure that you have the floppy setup disks so that you can run the Setup program from the floppy disk drive.
Note You can obtain Windows XP Setup boot disks from Microsoft, but only by download. We provide the Setup boot disks so that you can run the Setup program on computers that cannot use a bootable CD-ROM. If you can start your computer from a CD-ROM or from a network-based installation, we strongly recommend that you use those installation methods instead. Future products will no longer support installation by using the Setup boot disks.uparrow.gifBack to the topHow to partition and format the hard disk using the Windows XP Setup programYou can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps:Step 1: Partition the hard disk
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 How to use Disk Management to configure basic disks in Windows XP
uparrow.gifBack to the topAdditional notesBefore you can install an operating system such as Windows XP, you must first create a primary partition on the first physical hard disk (Disk 0) on your computer. Then, you can format a file system on that partition to create what is called the System partition.
Or, you can create a separate partition for the operating system on any physical hard disk. This is known as the Startup partition. The System partition on Disk 0 can also be used as a Startup partition.
Jun 19, 2011 | eMachines EZ1601-01 PC Desktop
Hi, I am adil. I am trying to install Windows XP on my Dell mini Inspiron 1020 but failed. Please provide me details steps.
Method 1: Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base: 313348 How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished.
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
How to install winxp to laptop dell inspiron 910. dell inspiron 910 no hdd but 8gb flash drive
313348 (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup program To perform a clean installation of Windows XP, follow these steps:
Post back if it is not working we will be happy to help you.
Thank you.
Cheers!!!
Jan 09, 2011 | Dell Inspiron Mini 10 Notebook
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
I am trying to install win xp with sp2 on my laptop. i was using vista on it before . it show this error message; A problem has been detected and windows has been shut down to prevent damage to your...
If you want both OS you need to do a partition on the HD to proceed.IThat what i can figure from your quest.But if you just want XP just do a clean installation of it.
Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:313348  (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Oct 06, 2010 | Promise SATA300 TX2plus...
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
I can not install Windows on my Compaq Evo N620c
The quickest solution here would be to put the hard drive into a computer that has Windows already running, and format it through the operating system itself. I've run into this problem a few times, and when another computer wasn't available I would use a Linux boot disk to clear out all my partition tables, then I would load up with Windows XP and tell it to write a new NTFS partition. Do NOT select the 'quick format' option, you'll have to wait through the long one.
May 04, 2009 | Compaq Evo N610C Notebook
My acer aspire t180 crashed a few months ago and i did not have a windows disk to reinstall it so i used the disk that i got with my dell pc(this seemed to work) but now i have bought a windows xp disk i...
Is the disk you have xp pro? If not, just do the xp home or whatever is on the disk. You may have to format your hard drive to clear it to accept the windows. Get plenty of advise before you do anything permanent like formating your hard drive. Get any factory disks that you can that will have your bios on them.
May 04, 2009 | Microsoft Windows XP Professional for PC
HDD Partition help
Important If you follow these steps on a hard disk that is not empty, all the data on that hard disk is permanently deleted. We recommend that you back up your hard disk before you follow these steps.
To partition and format your hard disk by using the Windows XP Setup program:
1. Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer.
Note To start your computer from the Windows XP CD-ROM (or from the startup disk), your computer must be configured to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive. In some cases, you may have to modify your computer's BIOS settings to set this configuration. For information about how to configure your computer to start from the CD-ROM drive, the DVD-ROM drive, or the floppy disk drive, see the documentation that is included with your computer, or contact the computer manufacturer.
2. If you are starting the computer from the Windows XP CD-ROM, select any options that are required to start the computer from the CD-ROM drive if you are prompted to do this.
Note If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver.
For additional information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base:
314859 Limited OEM driver support is available with F6 during Windows XP Setup If you are starting from the Windows XP Setup disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after you insert each disk.
3. At the Welcome to Setup page, press ENTER.
4. Press F8 to accept the Windows XP Licensing Agreement.
5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
6. All the existing partitions and the unpartitioned spaces are listed for each physical hard disk. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition by using unpartitioned space. If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each of the existing partitions that you want to use for the new partition. When all the partitions are deleted, select the remaining unpartitioned space, and then press C to create the new partition.
7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
8. Repeat Steps 4 and 5 to create additional partitions if you want them.
9. If you want to install Windows XP, use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER. If you do not want to format the partition and install Windows XP, press F3 two times to quit the Windows Setup program, and then do not follow the remaining steps. In this case, you must use a different utility to format the partition.
10. Select the format option that you want to use for the partition, and then press ENTER. You have the following options:
The option to leave the current file system intact is not available if the selected partition is a new partition. The FAT file system option is not available if the selected partition is more than 32 gigabytes (GB). If the partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm). If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
Note If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you will be prompted to select a file system for both the System and startup partitions. 11. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue. After the Windows Setup program is completed, you can use the Disk Management tools in Windows XP to create or format more partitions.
Oct 19, 2008 | Computers & Internet
ASUS P5GD1-VM Motherboard Logo
361 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
