Question about Panasonic PT-43LC14 43" Rear Projection HDTV
Reseting the lamp meter on tv
I got my replacemnt lamp for my panasonic lcd tv model #pt-52lcx65 and my manual does not explain how to reset the lamp time
  • mimihj Dec 25, 2008
    Lamp replaced--including new housing. Worked fine for a couple of months. Now it will shut off every few minutes and when I can restart it again it starts with the message: Replace lamp and reset timer. I actually starting getting the replace lamp and reset timer message when powered up about a month before this shutdown problem started. any clues besides sending it out for repairs?
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Posted on Dec 25, 2008
  • sam k Dec 22, 2010
    Thanks to you i was able to reset..
  • danboutin May 15, 2011
    I had to press the PIP button on my remote, not the Split or Play button. This was for the Panasonic PT-60LCX64
That solution worked for me.  I had the bulb replaced  a while back but the tech did not reset the hour meter. this worked fine. thank you
Posted on May 20, 2009
How do you reset the bulb life counter after you put in a new bulb?
For models:
PT-44LCX65/PT-52LCX65/PT-61LCX65/PT-52LCX15.
1) Make sure the TV is on.
2) While pressing and holding down VOL DOWN button on the TV, press and hold down the SPLIT DVD/VCR CH UP button on the remote until a message appears on the screen that the lamp timer has been reset. If this does not work, use SPLIT DVD/VCR CH DOWN instead.
Good luck
Dec 14, 2010 | Panasonic PT-52LCX65 44" HDTV
I need to lamp hour meter reset
HERE IS THE RESET LAMP TIMER INSTRUCTION
http://www.fixyourdlp.com/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!!!
Oct 12, 2010 | Panasonic PT-52LCX65 44" HDTV
How to reset lamp timer on panasonic pt-52lcx16
Turn On tv, press and hold Volume Down button on TV Front and Play/Split button on Remote at same time for six seconds to reset lamp timer.
TV screen will show lamp timer reset display upon successful process.
Jun 26, 2010 | Panasonic PT-52LCX65 44" HDTV
PT-52LCX65 Lamp Meter
Hello.. meseta809
first off all it's not necessary to have the TV on to reset it. the problem is the dmd need to send the info that you have a working lamp.
try this to see if it work's
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Ok, so apparently there are a couple of different ways forum members have found out how to reset their Panasonic Lamp timer (this should apply to all of them, not just the TY-LA1000 specific lamp)
“Hold the VOL down button on the TV and the SPLIT button on the REMOTE for five seconds”
Again, you will need to press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds, it will NOT work if you try to do it both from your remote!
Jan 15, 2010 | Panasonic PT-52LCX65 44" HDTV
I have a Panasonic pt-52lcx65-k. I thought the lamp was gone so i replaced it. Now the tv wont come on at all. Just a orange light flashing. I tried to reset it by holding the volume button and the pip...
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Dec 19, 2009 | Panasonic PT-52LCX65 44" HDTV
I can not get the hour meter to reset on my PT 52lcx65-k/ tv after I changed projection lamp
What have you tried to do for the reset?
I have a proceedure, but I am not sure if it is the same one.
Thanks
asnowman
Dec 08, 2009 | Panasonic PT-52LCX65 44" HDTV
I have red (3) & green (1) spots on my TV (PT-52LCX65). Does the lamp need to be replaced?
This is actually a memory error issue on the LCD driver panel board. This will require the repair from a Panasonic authorized servicer as there are no parts needed but they have to use a special reset tool that Panasonic provides to them. Call Panasonic and see if this is a covered repair since it was a well known issue. Please take a moment to rate my answer...Thanks..
Dec 04, 2009 | Panasonic PT-52LCX65 44" HDTV
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Pt-52lcx65-k
Turn power on.
Press and hold the volume down button on the TV.
Press and hold the "split" button on the original remote.
Hold both for for over 5 seconds in power condition.
Counter will reset and lamp indicator will go out.
Dec 05, 2008 | Panasonic PT-52LCX65 44" HDTV
I cannot reset my lamp clock
http://answers.yahoo.com/question/index?qid=20080221185527AAvGCui
I just now replaced my lamp and tried the solution on the above bookmarked site (hold down VOL- on the TV itself while holding down the SPLIT button on the TV remote simultaneously for several seconds... I didn't need all 20 seconds that this site recommends), and that worked for me. About 5-10 seconds in, I saw a blue box on my screen that basically said "Lamp timer has been reset to 0" with an "Exit" box below that. It took me a while to find the "Exit" button on my remote control to clear that box off the screen, but that's how I cleared it.
My TV is just short of 3 years old; I bought my Panasonic PT-52LCX65 on "Black Friday" (day after Thanksgiving) in 2005. My lamp died last Saturday night.
Hope this helps! -- ChuckE
Jun 06, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-43LC14 43" Rear Projection HDTV Logo
444 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
