Question about Sony Ericsson Walkman W810i Cellular Phone
I dropped my phone in the toliet
I dropped my phone in the toilet and it wont come back on i am so nervous.......
Try undoing the whole phone and take out the battery to dry out in the sun.
I put my daughters thru the washing machine and it came back on. Its worth a try.
Posted on Dec 21, 2008
My toliet keeps running. Have checked valves flap etc. I turned the water off , using the little toliet tap. Can I turn it on too much,making the pressure to high??
Replace the flapper. That is cheap to do. You can turn the water on near wide open And it should be ok. In other words, if you can't turn it on wide open, then something is wrong. I would just turn it on about 3/4.make sure your flat is not allowing the water to go over the top of the open tube.in the tank.
Jan 23, 2013 | Caroma 270W-RF Reflection Round Front...
Bought a american standard toilet tank to replace our leaky tank. after installation and turned on the water, but the tank is filling very slowly. what could be wrong?
Actually sounds like trash in the toliet water valve.....or possible that if teflon tape was used to seal threads has been drapped accross inlet threads and caused blockage......Best way to check this is to take supply line loose from toliet and slowly turn water on while pointing the supply into a bucket or something to catch the water and see if the pressure is ok......Then check valve to see if grit or blockage is in the toliet valve.........Depends on valve design to whether or not you will be able to clean....may have to replace toliet valve with new one......hope this helps
Sep 05, 2011 | American Standard Home
Toliet seat lid doesnt drop slowly anymore ( 4 yrs. old )
Either live with it or replace it. The hinge is not serviceable and the soft close action does not last forever. They rarely last more than five years, maximum.
Jun 19, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
The tank wiggles/shakes doesnt seem secure. I am worried if I crank down on the bolts the tank will crack. Also my ceramic floor is not quit even there is a crunching noice when you set on the toilet....
you are correct if you overtighten the bolts the tank will crack.
They make rubber spacers that go between the tank and the stool, that can be put in to help the part of rocking or wiggly, try that.
with your toliet making a crunching noise on the tile, my first question is does the toliet rock at all? i would try and tighten the bolts on the base or the next step would be to pull the toliet and put a new wax ring then tighten it down. It makes a crunching sound because part of it is hitting the tile so makes sure it tight to the floor
Jan 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
Can you just buy a toliet seat base??
Im not sure I understand the question so please excuse me. You can buy a toilet seat, and they usually attach to the toilet bowl. If the porceline that the seat is attached to is broken then the bowl will most likely need to be replaced. Most of the time you can replace the toilet cheaper than just replacing the bowl. Hope this helps.
May 09, 2010 | Home
Toliet that is leaking behind the wall
First it is not the toilet that is leaking behind the wall it is the water pipe in the wall that is leaking. You need to get a plumber out to fix the leak before you get mold. Now if the toilet is on second story it can be the drain pipe in the ceiling. You will also need a plumber to fix.
Good Luck and please rate 4 thumbs for the free answer.
Mar 28, 2010 | Avalon Home
My phone fell in the toliet
Switch off the phone as soon as possible. Allow it to dry else the circuits will be affected. Check if it works tomorrow, if it doesn't you might need professional help. Some components will require change.
Jun 03, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Tank will not refill after you flush
okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
Nov 16, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Sony Ericsson Walkman W810i Cellular Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
