RESET OKIDATA TONER DRUM
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100\%.
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time. 2. Menu window will show "OKI USER" 3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button. 4. "Diagnostic Mode xx.xx.xx S-Mode is indicated. 5. Scroll to "NV-Ram initial" is indicated. Push ENTER. 6. Window shows "NV-Ram- Initial Table 1". 7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window. 8. Restart printer.
Please Follow step by step..
8. Restart printer.
Read more help..error code 0xc18a0106 on c5180 Photosmart and HP Printer Support
All toner, drum, fuser and transfer figures return to 100%.
1.Turn machine on while pushing and holding
printer.
100%.
Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... U will be able to send and recieve faxes..... Thanku.............
Worked for me when I had the same error. Hope it helps.
