Question about Maytag MAV3855A Top Load Washer
MAYTAG Wahing machine model MAV6000AWQ
Machine is making a lot of squeking noises while on wash and spin cycle. How do I go about checking and repairing this problem? Pls. advise. Thank you King
  • Anonymous Mar 16, 2008
    Yes this machine is an extreme disappointment. I can't imagine th Maytag repairman being bored anymore!!
My washer has stop spinning.
Posted on Dec 27, 2008
  • 5,911 Answers
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Posted on Apr 29, 2007
It does not want to spin without making a lot of noise. What can i do it is only 4 yrs old
If it's a FAV6800A or FAV9800A run a Spin Only cycle with no clothes in
the wash basket. Do you hear noise like metal against metal? If so it could be Outer Tub Bearing noise. Please confirm you model number and first two digits of your Serial Number
Which is your machine? Rich
If it's one of these machine models we will continue
Feb 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Mav6000awq
well..that would certainly make it sound better. you might want to check the bearings and belts first though..
Mar 10, 2008 | Maytag MAV3855A Top Load Washer
My wahing machine makes the noise that it normally makes when it's in spin mode, but the tub isn't moving.
The belt probably broke.  The belt is on the bottom of the machine and if fairly easy to replace.  If it is not the belt it could also be the brake, but if this was the case you would probably be smelling burning rubber during the spin cycle.  The brake is just above the belt pulley.
Oct 25, 2009 | Maytag Performa PAV3200
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Maytag MAV6000AWQ won't spin
my maytag atlantis does not spin fast enough to get all the water out.
Oct 28, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Maytag MAV3855A Top Load Washer Logo
542 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
