Question about Philips GoGear HDD6330 MP3 Player
When I turn on my philips Gogear 6GB a message appears to connect to PC. However when I connect to the PC it does not recognise the device. The device Manager continues to indicate device not connected. What should I do to resolve this issue?
  • Anonymous Dec 22, 2008
    Have the same problem, looking for some help.
  • flash143 Jan 15, 2009
    I have a problem with my Philips GoGear 30GB. When i turn it on it tells me to connect to my PC however when I do this it gets stuck there and the device manager does not recognize the device as being attached. I have tried the reset function with no success. Can someone please help???
    New Friend:
  • 161 Answers
Hi Try to do a reset. When you switch the gogear on hold in the volume raise (+) at the same time.
Posted on Dec 23, 2008
While connecting my philips GOGEAR to my comp its not recognising the USB device plus it switches off automatically when i start the device.
The screen will turn off when you plug this unit in with the cord. For your device to be recongized, the latest drivers have to be installed for you device
Aug 30, 2009 | Philips GoGear SA178 MP3 Player
My player displays a message
Connect player to pc and power, restart player while holding the volume + key, as soon as the player shuts off, press and hold the volume - key, your device manager will pop up and tell you the player needs repair, let it do so.
Jul 18, 2009 | Philips GoGear HDD6330 MP3 Player
Message showing - player problem connect pc and fformat player
i have philips gogear sa 1356/97 mp3 player.it is not working .when i switch on the player a message displays "Player Problem-Connect to pc-format player". My PC not detecting the device.
Jan 19, 2009 | Philips GoGear SA1350 MP3 Player
Phillips GoGear Problem
Run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect the GoGear to the computer until a Found New Hardware Wizard window pops up.
-Tha Mp3 Doctor
Dec 19, 2008 | Philips GoGear SA5285/37 Digital Media...
Need assistance regarding my philips gogear 6gb HDD/1630/17 mp3 player
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Nov 30, 2008 | Philips HDD1630 MP3 Player
I have a philips go gead 6 gb when i cut it on it say please connect to a pc and it wont allow me to go to my play list it freezes
Sounds like the firmware is corrupt or deleted.
Install and run the Philips Device Manager from the product CD.
Connect the player to the PC.
Wait for the PC to recognise the player then select the Repair/Restore option and follow the on-screen prompts.
This will format the player and reload the firmware.
NOTE: ALL TRACKS WILL BE DELETED FROM THE PLAYER
If the problem persists, it could be a faulty hard disk in the player. This is a standard Microdrive.
If this is the case, www.cheapestelectrical.co.uk have a couple in stock. (Only 6GB). They are not on the site, so you will need to e-mail them.
May 05, 2008 | Philips GoGear HDD6330 MP3 Player
No device connected
Try installing the newest version fo the software from the Philips website first.
www.usasupport.philips.com
Enter your model number
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "software and drivers"
If that fails:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear Mp3 player problem
Jan 04, 2008 | Philips GoGear HDD060 MP3 Player
Philips go gear 6gb not connected.
-Tha Mp3 Doctor
Nov 25, 2007 | Philips GoGear HDD6330 MP3 Player
Philips 1630/17 6gb mp3 player
-Tha Mp3 Doctor
Oct 09, 2007 | Philips HDD1630 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
95 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
