Question about Microsoft Xbox 360 Console
Dvd drive will not open - Microsoft Xbox 360 Console
    Problem Solver:
  • 11 Answers
You have to ensure that everything is in place. Try to pull it out by force and if it nudges just oil it a bit.
I have not yet opened a xbox 360 but i bet you will have to remove teh casing, and should then have a visual of this belt.
dvd drive will open
Posted on Dec 21, 2008
  • 34 Answers
If the drive sounds as though its trying to open, then its most likley the rubber belt wich should be located right below the tray where the cds are placed onto. I have not yet opened a xbox 360 but i bet you will have to remove teh casing, and should then have a visual of this belt.
Does the Toshiba Satellite C55-A-14W Laptop have a manual over ride button to open the DVD/CD Driver Draw Tray
If the DVD drive does not have an "Open" button, press firmly on the right side of the DVD drive tray and then release it to open the drive. To force the DVD drive to open, straighten a paper clip and insert it into the small hole on the outside of the DVD drive; push and hold the paper clip until the DVD drive opens.
Jun 20, 2017 | Toshiba Office Equipment & Supplies
Actually my dvd is not opening when i m pressing the open/close button.
It could be a "physical" problem.
Take a Norwegian paper-clip, and straighten one end.
Insert that end into the small hole in the face-plate of the drive,
and push until you feel resistance.
Then, firmly push another 10mm (1/4 inch) and the drive should "unlock" and open slightly.
Press the open/close button to fully open the tray.
Dec 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Dvd drive not opening. It flashes the light but it doesn't open. It is reading dvd or cd without any problem. The only problem is that it is not opening.
there are two solutions for this:
first go to MyComputer, right click on your DVD drive and click Eject. if it does not open the try the following.
on your dvd drive there is a small pinhole. get a stapler or something small tha fits that hole and push it through. this was your dvd drive will open. it will not harm your dvd drive.
Jan 27, 2010 | Toshiba Satellite L305-S5926 PC Notebook
The dvd door fail to open
To open this drive you can open My Computer and right click your DVD drive and select eject. You can also open any CD/DVD drive by taking a paper clip (or something the size of one) and inserting it inside the tiny pinhole near the eject button on the drive.
Jan 13, 2010 | LG GSA-H22N DVD±RW Dual Layer Burner
DVD burner drawer will not open every time the button is pressed. When it does open a disk must be in the tray in order to get it to open again.
Most PC DVD/CD drives have a small hole just large enough to insert an unfolded paper clip this will release the rack and pinion drive the the tray will open for you
Dec 09, 2009 | Dell 16X Internal DVD-ROM Drive for...
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
Dvd won't open program
Does your dvd drive opens other dvd's if it does, that means your dvd has gone bad but if your dvd drive fails to play any dvd's than it's a problem with your dvd drive.
Best way to test it would be to insert a new empty dvd and see if your dvd drive opens it.
Jul 26, 2009 | Dell Computers & Internet
DVD drive
Good day!
Let's try to open your dvd manually. Look at your dvd drive you will find a small hole just beside the push botton, find a long pin push that pin side the hole, it will open you dvd. Push the dvd botton and try to open it again.
Thanks.
Nov 01, 2008 | LG Computers & Internet
Unable to Open DVD Drive.. have Fujitsu drive
may be u r drive door s are stuck.....try to open it by a needle....
or further it is damaged u can replase it if in warrenty.
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 21, 2007 | Dell 8xDVD/24xCD Drive for...
Microsoft Xbox 360 Console Logo
43 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
