Question about Microsoft Xbox 360 Console
Slot will not open
Press the button and you hear the door try to open and it doesnt
    Problem Solver:
  • 11 Answers
Yko has recently released an updated Intercooler that uses its own power source. Nyko claims this problem no longer occurs with new versions of this cooler. However, Microsoft still considers it an unlicensed add-on and will void the warranty of machines showing signs of its use.
Posted on Dec 21, 2008
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
Door lock system
Try and replace the battery on the key fob device. If that doesnt work, the fob has gone bad
Jan 08, 2014 | 1998 Ford Explorer
Laptop problem
If the fan runs and you see lights that's a good thing. It means the laptop is getting power and trying to boot. Now do you hear the hard drive turning? When you press the Power Button do you hear the CD drive click once and notice that the light on the cd drive door turns on for a second or two? These are all good signs of the laptop trying to boot. When you press the power button did you hear any beeps or notice that the lights blink continuously such as 1 long beep and 2 short beeps. The lights and blinks tells the technician what is wrong. When you press the power button do you see anything on the LCD Screen as it goes thru the boot process?
Try removing the battery and the power cord from the laptop. Then press and hold the power button for 30 seconds. After 30 seconds, plug only the power cord in and press the power button to reboot. If it boots that means you had a static buildup which is normal in computers. By hold the power button you released the static. If it boots you can put the battery back in. If it does not boot and if the lights are blinking or you hear beeps you might have a bad memory chip. Unplug the laptop and turn it over to remove the screws tht house the memory chips. Remove one of the memory chips and set it aside. Now try to boot your laptop. If it does not boot, move the memory chip to the other slot and try rebooting. If it boots place an x on the memory chip that you have set aside. If it does not boot remove that chip and put the memory chip you have set aside in the laptop and repeat the process of moving in into each memory slot and trying to boot. If you get it to boot with one memory chip, place the other chip in the available slot (make sure it has an x mark on it so that you will know which one might be bad), then try rebooting. If it fails, that chip is bad. If it does not boot for either chip then more than likely you have a motherboard issue.
Mar 20, 2012 | Compaq Computers & Internet
Hp f30 has new ink cartidge and paper but ink button still flashing and not printing alignment page.
Here are some steps that can help you resolve the problem.
Close the cartridge access door securely, if cartridge access door is open even slightly, the print cartridge light will blink.
1. Open the cartridge access door, once carriage moves to the center of the printer.
2. Check inside the printer and make sure that there are no obstructions that are preventing the cartridge access door from closing , if there's any obstruction remove it.
3. Close the cartridge access door completely.
Do the Print Self Test
Press and hold the Cancel button, and then press the Start Copy Color button
Release both buttons at the same time
If the issue persists, Make sure that the cartridges are installed
2. Wait until the carriage is idle and silent
3. Check the cartridge slots in the carriage to make sure that the cartridges are installed.
4. Try to reinstall it again.
5. Lightly press down on a cartridge to release it, and then pull the cartridge toward you out of its slot.
6. Check the nozzles on the cartridges to see if the protective tape is still attached
Note: Do not touch the copper-colored contacts or ink nozzles
7. Hold the cartridge by its sides
8. Slide the cartridge into its designated slot at a slightly upward angle.
9. Press the cartridge inward until it snaps into place
10.Close the cartridge access door
If still the problem persist contact HP for the service.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 10, 2011 | HP DeskJet F380 All-In-One Printer
Door will not open
make sure the drive is not reading a disk, because if its spinning it can break when you do this process.
look for a hole in the front of the drive, get a paper clip and stick it in there all the way, the tray will now eject or if its a slot loading drive the cd will eject
Sep 06, 2010 | Computers & Internet
Apex dvd player door will not open
Can you hear any noises from the drive when you press the Eject button? if no then the motor is faulty but if you hear noises but it still doesnt open then the belt could be slipping or broken.
Nov 04, 2009 | Apex Digital AD 1115
Unable to open the door of the dvd --when you press the eject button to open the slot---the door does not open---everything else works
Quick trick
First let's find out if the motor is dead or
the magnetic clamp is to strong for the motor.
Press eject then listen closely for the sounds of struggling motor
if you hear it trying SLAP the top right over the DVD drive
and that should break the magnetic seal and release the tray
you may have to try a few times Press eject and open hand slap kinda
hard the top of the DVD drive , don't worry you won't hurt it.
if that works email me and ill tell you how to fix this.
Rob
rsheehan@northernsteeldesigns.com
Oct 14, 2009 | GoVideo Go Video DVD/VCR Combo
Remove a cd that won't eject from a dell 1530 slot
There is a button (one of the touch sensitives ones up by the power button. You have to press it over and over and over again till it comes out! f that doesnt work then completely turn off the system and before it gets to where you put in yor password (anywhere after you press the power button just nt password place) and then it should pop out!
HTH! =D
Feb 24, 2009 | Dell XPS M1530 Notebook
Press button fuel door won't open,can hear click
try using the manual release lever on the upper left side in the trunk. If it still won't open then the door may be jammed.
Jan 07, 2009 | 1999 Cadillac DeVille
How do I change HP 5610 print cartridges.
gtabseps.gif Introduction Follow the instructions below to replace the print cartridges. This document applies to the following products:
  • 5605
  • 5608
  • 5610, 5610v, 5610xi
Replace the print cartridges Step one: Remove the print cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on. Figure 1: Press the On button to turn the product on c00442142.gif 1 - On button CAUTION: If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Figure 2: Open the access door c00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. Figure 3: The print carriage c00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper position c00442144.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Jun 21, 2008 | Office Equipment & Supplies
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
