Mid 80's vintage Whirlpool Imperial 70 clothes washer
The washer would not drain. Wife kept trying on/off/on/off etc. until it no longer made any noise at all.
I drained the unit, cleaned the water pump lint trap (disgusting! definitely the cause of the trouble), checked the water pump, reassembled, set upright, plugged in again (to a live socket). Not a single sound beep click or other sign of life is evident.
If the stopped drainage caused the system to shut down, how do I get it to reset? Is there an internal fuse or switch or something I should check?
Thank you.
    President:
  • Washing Mach... Master
  • 2,651 Answers
Its possible tha tafter reassmebling the top/cabinet, you neglected to plug a plug back together, under the console area, sounds like this for if the machine has adequate power supply you should, at very least get water to come the machine check your connections under console area
Posted on Dec 21, 2008
No heat whirlpool electric dryer imperial 70 1986 vintage
replace cut off switch fuse at the top of heater box
May 02, 2010 | Whirlpool GGQ8831L Gas Dryer
Whirlpool washer periodically will stop mid wash cycle. And won't restart until hours later. Seems to only happen when I need to do lots of laundry what is going on
THIS IS A BALANCE PROBLEM, IF YOU ARE PUTTING A LOT OF CLOTHES IN AT ONE TIME, YOU WILL HAVE TO BALANCE THE CLOTHES WHEN IT STOPS, DONT OVERLOAD IT, AND MAKE SURE YOU ARE EVENING THE CLOTHES OUT IN WASHER ESPECIALLY BLUEJEANS AND HEAVY THINGS, I KNOW MY WIFE DOES THIS HA, TRY THIS AND LET ME KNOW THKS LARRY
Apr 26, 2010 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Mid 80's vintage Whirlpool Imperial 70Dryer shaking
Check that the rollers that support the drum are not flat on one side.
Dec 20, 2009 | Washing Machines
Kenmore 70 washer, does not move from one cycle to another
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This appears to be a timer / timer motor problem.
I'd also look at the Whirlpool / Kenmore direct drive installation and maintenance manual for testing the timer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sep 26, 2009 | Kenmore Washing Machines
My kemore 80 series washer wont spin
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} We had the same (plus another) problem with an old Kenmore top load, direct drive,neutral drain washer.
Problem 1. Major gear sounding grinding during spin mode. Major vibration also.
Problem 2. Spin problem. Most times the washer would drain but wouldn't spin unless the lid was raised and lowered. (According to wife, this problem has been on-going for two years).
After checking motor coupling (a bit worn but intact), drive block (you don't need a spanner wrench to remove it, a 12 - 14 inch pipe wrench works great) which was OK, clutch, seemed OK, we determined that the problems were in the transmission.
Two options, 1 spend $150 plus for a transmission.
2. Open it up and see if anything seemed seriously bad.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
the first problem seemed to be related to the agitator cam and cam follower not raising the agitator gear high enough (probably less than a 1/16th of an inch) above the agitator cam.
Found the right part number (Whirlpool part # 62580 / 81) which includes both the cam and follower. Bought one for about $10.50, installed it, put washer back together and problem 1 was solved.
Looked again at parts list and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
Those cams/gears etc. keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
Put the washer back together and I now have a happy wife. Everything works as it should.
NOTE. Fixing the washer takes a little mechanical ability (wrenches, socket sets, screw drivers, vice grips, short pipe wrench) and a solid desire to save some money.
All told parts cost less than $30 (I also replaced the old transmission oil with 80-90 weight oil from an auto parts store) saving over $125.
Sep 15, 2009 | Kenmore Washing Machines
Replacing spin belt whirlpool clothes washer
There is no belt. This is a direct drive unit. There is a motor coupler located between the motor and the transmission.
Dec 26, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
715 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
