Question about Sony (CRX100E) CD-RW Burner
Playing a DVD compatible only CD rom
How can i play a game that is only DVD compatible? Will I have to purchase a new CD-rom/dvd combo or is there a way around this??
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Posted on Aug 10, 2007
  • 1019 Answers
SOURCE: Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 24, 2008
SOURCE: my sony CRX320EE CD-RW/DVD-ROM COMBO Drive is not
im having sony CRX320EE combo drive. it can read cd but cant read dvd. plz help
Posted on Feb 27, 2010
  • 113 Answers
SOURCE: My Samsung CD-RW/DVD-ROM Combo Drive
try these steps
) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Posted on Jul 06, 2010
My Sony CRX830E combo drive will not read any of the DVDs I have tried to play in it. The message it gives is that a compatible decoder is not installed. Is this a software issue, or do I have to buy a...
Control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select no _ for your specific area
Jan 02, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have a Dell laptop 4100, It has a cd-rw drive, plus a zip drive and a floppy drive, all interchangeable, I need a drive that will play a dvd and can be used to play game cd's, what do I need and where...
You need atleast a DVD-ROM drive. You can get a drive that burns DVD+r,-r,+rw,-rw. Either will be fine to play dvds. You can try newegg.com,tigerdirect.com,directron.com,geeks.com.
Nov 01, 2010 | Computers & Internet
Dvd combo not detect dvd's
Your Lense has some issue.
You can clean your lense with disk cleaner disk.
Pur chase it from nearest shop it is called "Lense cleaner disk"
then put it into combo drive then play it then it clean your lense then check .
If still not access your dvd then if it is in warrenty go to service shop they replaced it.
And if it is not in warrenty then you should need to repair your lense or purchase new lense.
Thanks
Jul 22, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My lg dvd rom play cd doesnot play dvd
DVD NOT DETECT ONLY DETECT THE VCD
PLEASE GIVE THE SOLUTION
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Decoder missing, can't play dvd
Your DVD drive should have included a dvd playing software, such as WinDVD or PowerDVD. If it didn't, you may need to purchase one of these or install the Elecard DVD Codec for free. This link may work:
http://fileforum.betanews.com/detail/Elecard_MPEG_Player/1016751417/1
Feb 18, 2008 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
I`m having a problem with my Acer Travel Mate 2200 laptop
in order to play a DVD you need to have a software dvd player Like WIN DVD, otherwise DVDs will not play
Jul 25, 2007 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Sony (CRX100E) CD-RW Burner Logo
44 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
