Question about Nikon Coolpix 5700 Digital Camera
Monitor is black w/ no image
Camera has been sitting up for approximately 9 months in dry air conditioned and heated home. When turned monitor is black with no mage. All other functions appear to work. Can review previous photos on view finder and monitor; flash fires and blank photo is recorded. Appears that shutter is stuck and gentle tapping of case has no effect. Is there a DIY solution?
  • 1 more comment
  • Anonymous Nov 04, 2007
    I have the same problem can you help
  • Anonymous Nov 08, 2007
    I have the same black monitor problem as described by "gambol". I saw the solution provided by "guest". Thank you so much.
  • Camerabuff Nov 10, 2007
    I also have the same problem. Camera sat in the closet for several months. Did not see a date on the service advisory. Hopefully, it is still valid. Thanks.
This qualifies for the service advisory @ http://www.nikonusa.com/email_images/nikonusa/service_advisory/coolpix.html. I had the same problem and they repaired it free of cost. Send it to them today.. Good Luck...
Posted on Apr 16, 2007
No image can be seen in the monitor
hi,
try this trick:
take a torch light and put it at approximately 30 degrees from your screen when the camera is running... can you se a bit off images ? if yes, your LCD back light is dead or the control chip is dead, or the ribbon cable is broken or just mooved...
Apr 11, 2014 | JVC Video Cameras
My monitor has turned vertical
go to monitor setting in display and click rotate .. this should fix the problem.
Sep 10, 2012 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
When turn on, two black do appears on the monitor
Moisture got into your camera. Dry it may work or replace lcd screen if available from ebay parts camera.
Jul 15, 2012 | Olympus Stylus 7030 Digital Camera
Monitor often will not power up when power button is pushed. Disconnecting power for 90 seconds corrects problem. This is an intermittent problem that is occuring more frequently over time. Condition...
I think there is a problem in Monitor's Power Supply unit which integrated in the base board of Monitor. If u expertise with the service then carry on. else Pl contact a Local Service professional to solve the problem
Aug 23, 2009 | Computers & Internet
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Same problem
It may be the back plane lamps, and or the back plane power supply that is in a failing condition. If in your model they are changeable, they should be changed together.
You can verify this by turning on the monitor, feeding it with a known working source, and shine a flashlight in to the screen at an offset angle to your view. If you can see some image in the screen, then you know that the monitor itself is functioning, and the problem is back plane lumination.
Jerry G.
May 07, 2008 | ViewSonic VX900 19" LCD Monitor
Image not visible on monitor screen
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Screen has 1 solid bright vertical line
a mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Sep 30, 2006 | ViewSonic G810 21" CRT Monitor
Fully charged battery last
Approximate number of recording images and playback times based on Minolta' s standard test condition* are as follows: *test condition: CIPA-compliant. (LCD monitor on, 1600x1200 size images, Normal image quality, Flash used with 50% of the frames) Recording Alkaline batteries : Approx. 80 frames Ni-MH batteries (2100mAh): Approx. 410 frames CR-V3 : Approx. 720 frames Playback Alkaline batteries : Approx. 275 min. Ni-MH batteries (2100mAh): Approx. 340 min. CR-V3 : Approx. 518 min.
Sep 19, 2005 | Konica Minolta DiMAGE E323 Digital Camera
How long does a fully charged battery last?
Approximate number of recording images : AA size Alkaline batteries: 240 frames *1 AA size Ni-MH batteries (2500mAh): 420 frames *1 Test condition Conforming to CIPA(Camera & Imaging Products Association): *1: LCD monitor on, Full-size images: 2560x1920, Standard image quality, No instant playback, Flash used with 50% of the frames, No full-time AF, one image at every 30 sec., turning the power on/off at every ten images. Approximate period of playback images: Test condition Based on Konica Minolta's standard test method: AA size Alkaline batteries: 240 min. AA size Ni-MH batteries (2500mAh): 330 min. *Since the performance may vary depending on conditions, recording mode, and subjects, these are approximate values only.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
160 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
