Question about Radio Communications
Magnum delta force
I have a Magnum Delta Force radio that I want to wire a CA-76 Cobra power mic. to it. Need pin# to wire color info. Thanks
  • 2 more comments
  • tricponi Dec 24, 2008
    The Radio will transmit but no rec audio help
  • cbtrader Dec 29, 2008
    Great info. Thanks so much.
  • tricponi Dec 30, 2008
    Radio talks but dos not receive could it be the audio chip or the voltage reg.
  • Anonymous Mar 25, 2014
    how do you wire this raido to the cobra ca76 mike
  • 170 Answers
Pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Posted on Dec 28, 2008
  • Katherine Dornemann Nov 13, 2012
    Do you know if the color coding is the same for the Motorola HKLN 4477?
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
Must know the pin out of the transceiver your wiring it too.
like cobras 1.ground 2.audio 3. TX 4. RX... then wire accordingly.(same as the 4 pin exports)..
Use a ohm meter to find the correct wires on your mic switch.
then you know how to wire any mic to any transceiver.
This will work for the turner 2+2
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
May 25, 2014 | Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
Magnum Delta Force Radio: The schematic does not match what is on my work bench! Schematic shows 10 tact switches,there are eight on the unit. If I trace back the leads from the rotary frequency changer...
usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
Feb 28, 2009 | Magnum DeltaForce CB Radio
D-104 mike wiring
Go to cbtricks.com look up radio information go to magnum use the wiring set up for the 357.
Jan 19, 2009 | Magnum DeltaForce CB Radio
Mic wiring prob.
From the Astatic wiring guide, here is the information for the DELTA FORCE
WH-1
BK-2
RED-3
SH & BL-5
Rollin CBs
Dean
Dec 09, 2008 | Magnum DeltaForce CB Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Wiring a mic
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Dec 23, 2007 | Magnum OmegaForce S45 CB Radio
Radio Communications Logo
195 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
