Trying to program my tv using comcast remote control my tv is a toshiba 36" the remote is the on demand comcast remote control.also the instructions will also be needed
I've gone through the program codes for a Toshiba I could find online and even tried comcasts 990 thing. Anyone out there have an idea how to fix this?
You can't post conmments that contain an email address.
Hi, the Toshiba codes given at comcast.net web site are: 10156, 11935, 10832, 10036, 10149, 11343, 11959, 10060, 11265, 11369, 10003, 10154, 10250, 10781, 10178, 10702, 11314. One of these should give you control your TV. If you were to still have a problem try their web site direct and contact their customer service, you might need another remote.
with comcast remote with red ok select switch the toshiba codes are 11256 most likely, other codes are 10154, 10156, 11265, 10060, 10650, 10845, 11156, 11356, 11656, 11704
with comcast remote with grey ok select swithc the toshiba codes are 0154, 0156, 0060
Dale
There is a code out there to try. The code would be 47. Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Go here, it has a viewable manual for the comcast remote and a list of codes. There is also a way to search codes listed. Haven't tried yet, but it can't hurt trying!
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
