Question about Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV
Can you tell me where the fuse on my 1999 polaris 400 explorer?
I have a1999 polaris 400 explorer atv and my speedometer,cooling fan,reverse and neutral light and the 4 wheel drive all stopped working at once and i cant find a fuse on the machine
  • hornetmaster Jan 10, 2009
    I just came up with this same problem, put a new battery in it and still go.I will look at the breaker. But to add, could this breaker also have an impact on my starter not wanting to pull over all ther time?
    Thanks for you imput!
  • 36 Answers
Check the battery for a shorted out cell.When these machines battery goes they will blow every bulb or almost every bulb.
There is no fuse just a circuit breaker that controls everything.It is located in the rear section inside a black plastic bag.
This may just be the start of a long process to get everything eliminated. Electrics can be a pain but in time you can trace it.
Posted on Dec 27, 2008
My Polaris Sportsman 400 cuts off when i put in reverse and my dash + headlights do not work. Where is the fuse box?
YOU PLACED THIS QUESTION UNDER POOL PUMP, BUT I WILL GIVE IT A TRY. MOST OF THE TIME, THE FUSES ARE IN THE HEADLIGHT ASSEMBLY ,, ITS LIKE THE ONLY DRY SPOT ON IT, OR YOU CAN SEARCH NEXT TO THE BATTERY .. THE CUTTING OFF MAY BE A SEAT SWITCH, PULL THE SIDE COVERS OFF AND DO SOME SNOOPING AROUND, YOU MIGHT FIND A FUSE BOX THAT TELLS YOU WHAT FUSE DOES WHAT.ON THE INSIDE OF THE LID. IF YOU HAVE NO LUCK .. TRY YOUR SEARCH AGAIN UNDER THE RIGHT CATEGORY.. OR DO A GOOGLE SEARCH FOR 4 WHEELER CLUBS FORUMS .. THERE A REAL GOOD SOURCE WITH PICTURES !! AND DON'T FORGET ABUT ME .. CLICK ON THE YES AND LEAVE A REVIEW .. COOL AND THANKS MAN .. JAY THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA
Jun 17, 2011 | Polaris ATV
I have 97 Polaris Express 400 I haven't ridden in a while. Put new battery in it, new fuel, cranks, runs great but overheats. I checked the radiator reservoir and it is full. Any suggestions? How can I...
U should have two sensors for the cooling system one is nerr the thermostat housing for temp light / gauge ,one on the cooler at the bottem left side should have two wires on it need to pull them off connect the two togather. That should make the fan come on, if not, look for a popped fuse should invest in a handheld inferred thermometer ,there really cheap .get them on eBay for between 11 to 20 bucks brand new use it to test temp on coolant hoses to see temp on top and bottom .if fan does come replace cooling fan temp sensor.
Mar 03, 2018 | Polaris ATV
1996 Polaris Xplorer 400 will shift into high and reverse but not into low.
I need the direction's for the proper shifting adjustment's on a 1995 Polaris 499 Explorer
Jan 23, 2011 | Polaris ATV
4-wheel drive does not work in reverse when override switch is used on my 1999 explorer atv.
I had a problem on my 500 sportsman ...4 wheel drive just stopped working. Oddly enough it was the speedometer cluster. I got some info online telling me which female connections to jump over with a piece of wire . Four wheel drive works fine now ...dont have a speedometer ...but im not out three hundred dollars for a new cluster.Hope this helps
4x4ever
Oct 18, 2010 | Polaris ATV
Working on a 1999 Polaris Explorer 300, does it
on a polaris 4x4 hawkeye where is the fuse box
Jun 22, 2010 | Polaris ATV
Polaris ATV: battery will not stay charged 1996 400 polars...
The magneto is probably bad if all of the wiring is good.
May 06, 2010 | Polaris ATV
I HAVE A 1999 POLARIS EXPL 400 THAT WILL NOT GO INTO 4X4 ???
The problem sounds like your speedometer. I just fixed mine with the following solution.
Pull the 6 pin plug from your speedometer, On the plug, short the brown wire with the Brown/White wire. Tape it up and do not place back on your speedometer.
Your speedometer will not work but your AWD will.
Let me know if this helps
Joe
Jan 18, 2010 | Polaris ATV
Interactive Toy Concepts Polaris Sportsman 800 Remote-Control ATV Logo
1,950 people viewed this question
Top Interactive Toy Concepts Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Interactive Toy Concepts Toy Expert? Answer questions, earn points and help others
