Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL2060. Can't unscrew the cover to clean out blockage.
My machine won't drain and suspect hairpins and other debris. You need to unscrew the cover at lower right to clear out debris and let the water drain.However it has become stuck.An appliance store suggest you need to turn as far as it will go and then pull.Doesn't make sense as it is a screw mount. It did not seem to work.Any ideas to make it budge and turn.
  • 2 more comments
  • Anonymous Dec 22, 2008
    The exact same situation!!!
  • alicia2008 Dec 31, 2008
    We have the same problem. Even using a pair of pliers to try to loosen, but to no avail. Eventually we have broken the fins normally used for turning this plug. It's turning into quite an epic issue and we're still at it. We also know of family members with the same problem, so obviously a design fault. It's been a great machine apart from this - will just have to hope that the local agent carries these covers as spare parts...?
  • Anonymous Jan 21, 2009
    Guess what. Same thing exactly just happened to me. The screw thread would not move much at all, so I didn't even get to the part of the process where you could 'pull'. Now I have also broken off the fins in the turning plug. I have been searching online to buy the 'pump cap' as a soare. This is hoew it is described in the manual, however I can only fing 'filter pump' for this model in any spares list. The picture looks the same as what I have just broken anyway.
  • Alyce Edgar May 11, 2013
    iN the midst of trying to get our pump cap out. It also came to a hard stop after 1/4 of a turn counter clock wise. Our dryer is stacked on top of our washer so it's difficult to turn the washer on its back like some people have suggested.
  • 3 Answers
I had the same problem.First, open the cover panel at the bottom right of the front of the washer (push the release down at the top of the panel (about 4 inches off the floor). Next, drain the water into a shallow pan by pulling out the black tube (to the left of the big round pump filter plug) and pull off the cap on the end of it. Next, (sometimes the hard part) unscrew the pump filter plug. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
Posted on Apr 16, 2009
  • Gerry Berry Sep 15, 2012
    Thank you Neobug! The "It takes 2 full turns to get past the threads in order for the plug to come out" did it for me as the user manual I have just says "Carefully remove the pump cap"! I used a pair of vice-grips and gently coaxing the cap to turn twice... I had a 6cm lolipop plastic stick and a metal paper clip inside. Now it is cleaned and working well. GerryBerry
  • Bosch Master
  • 3,463 Answers
You do screw it to the left to undo it as much as you can, if it is stuck, then just keep gently pulling and trying to move it from side to side, screw it back in and out again, all the time moving it about as much as you can, hopefully you will eventually get it out to clean.
The fact that you are having trouble getting the filter out indicates that something is stuck in the pump filter, and this is what is holding it.
Just stick with it!!!
Plz rate my solution.
Thanks, and a merry xmas.
Posted on Dec 21, 2008
  • lynn_mcatamn Dec 19, 2010
    Cool getting washing machine advice from a guy in a bow tie. Thanks :-)
I had the same problem but the cap/cover was only turning about 1/8 of a turn and coming to a hard stop. I spent a long time jiggling and wiggling the cap to no avail. I thought if I lied the washer on its back it may release what was stopping the cap from turning (I unplugged all water and power sources first). Anyway still no joy. Had a look up under the washer and saw the pump. There is a hose that enters the pump held on by a quick release hose clamp. I used some pliers and carefully removed the hose and stuck my finger in the pump opening. Instantly found my sons DS pen. Removed this securely put the hose back onto the pump. Tested the cover and it came straight off. approx 2 turns. HTH.
Posted on Dec 21, 2009
  • nathan_holme
    nathan_holme Sep 08, 2012
    very helpful thanks. turning on it's back and getting into the back of it was perfect. We had a nail and a drill bit in ours!!
  • nathan_holme
    Very helpful. I turned it on it's back and took off the hose at the back as well. We had a nail and a drill bit in ours. Thanks
    New Friend:
We just had the same problem and this blog helped. Our pump cap only turned at most 1/4 of a way counter clockwise. It was definitely a hard stop and we didn't want to use brute force as we heard it would potentially break the cap. We found a solution! If you happen to be a wood worker, you may have these already but get two plastic Irwin Quick Grip Wood Clamps. We secured the lid between two of these clamps, using the plastic yellow feet and just turned counter clockwise. After a couple of times of turning the cap, some water drained out, so have a flat pan and towels on stand by. We found a gunk of hair, and 4 brass collar stays and a small plastic clip usually found in men's dress shirts! Now the machine runs well and doesn't make weird engine sounds before it starts! Very happy! Good luck guys!
Posted on May 11, 2013
Remove wfm 3200 pump
Hello, welcome to FixYa.
I understand you are having trouble removing/locating the filter access cover on your Bosch Nexxt washer, correct ?
I've posted my solution to error code E13 which should in turn explain to you how this covered should be removed...the first 3 steps should explain/illustrate how this is done, you can omit the rest if you like or review for cleaning procedure.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs, and a pair of mechanics gloves are recommended due to EXTREMELY sharp edges...safety first**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water that is typically the reason for a locked door, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine as you know (about 6" in diameter, lower rightcorner)
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free...it will not rotate unless the release tab is pushed in. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a green ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Oct 25, 2011 | Bosch WFMC 3200 Front Load Washer
My washer wont drain and i cleaned the drain tube. what else should i check or replace to make it work?
Remove as much water from the tub as possible. Remove the three screws from the bottom front of the washer. You may have to tilt the machine back to get access to the screws. Remove the lower panel. Right in front is the clean out for the pump. Have several towels or a shopvac ready to catch the water. Unscrew the cleanout from the pump. Remove all the coins, lint, hairpins, bra wires and other debris that has accumulated in the trap. Reassemble and test.
Mar 05, 2011 | Whirlpool GHW9400 Front Load Washer
Water is not drained from the tub when washing of the dishes is complete
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote if you liked my answer
thanks
Feb 13, 2011 | Bosch SHX45P05UC Dishwasher
The water does not go down after cycle is done. kenmore 417-43042200
remove the lower toe kick panel below the door and remove the clean out trap,its a 2 to 3 inch round plug and it unscrews and it is probably full of debris coins,nails,hairpins,etc,this stuff will block water flow during drain cycle
Jan 29, 2011 | Kenmore HE2 Plus Front Load Washer
Does not drain the clothes completely
Hello, welcome to fixya.
I would start by checking a couple of crucial factors.
Confirm your washer is indeed a Bosch WFL2060 before going forward.
1) Are you using "HE" detergent ? If yes, good, move to next question. If not, you must. The Bosch front load washer's will not function as was intended unless hi-efficiency (HE) detergent is used.
2) Have you checked your drain pump for obstruction or debris ? No, look below to see how.
If yes, will the unit drain and spin if empty of clothing ? If it drains but won't spin, ( or if it rotates in only one direction ) you likely have worn motor brushes.
To check the drain pump...
**Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first**
1) Open the small square plastic door at the right bottom of the washer.
2) Via the small hose drain any access water from the pump...this is where a wet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well.
3) Then turn the pump insert/button trap counter clock-wise and pull out. Clean the trap out thoroughly, and inspect inside the pump for any other foreign objects/obstructions.
Let me know how you make out, or if you require further assistance.
If this indeed solved your problem, whether it be the detergent ( have to use "HE" no exceptions ) or pump blockage, please take a moment to rate my solution.
If it is the other possible issue for not spinning, "motor brushes" check out my tip...
http://www.fixya.com/support/r5082734-yes_change_some_bosch_washer_motor
Thanks for visiting "fixya" today and good luck.
macmarkus :)
Jun 22, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I need to clean the drain pump but before I do I want to make sure what I think is the pump really is. I have the front panel off so is the drain pump white and in the front? I'm assuming it is because the...
The drain pump is easy to clean. It is white and has around cover facing the fron on the bottom. Take 3 screws out and remove the bottom cover, unscrew the round cover off of the drain pump, pull it out, and clean out all the coins, toys, hairpins, whatever else has been left in pockets and gone into the washer. When you screw the cover back on make sure the gasket is seated properly. Also, expect some water when you remove the cover.
Apr 17, 2010 | Kenmore Elite 45986 Front Load Washer
Bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Unscrew anti-clockwise to remove and clean.
Mar 30, 2010 | Bosch Washing Machines
My bosch exxcel has water sitting in bottom and doesn't appear to be draining down.
Check to see if there is a removable lower plastic cover at front of washer, if there is, then remove this, and you should find the pump filter located here, unscrew anticlockwise to remove and clean.
If no sign of filter, then remove rear panel of washer, and access the pump from here to check for blockage.
Please rate my solution.
Thanks.
Nov 09, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Washing machine broken, flashes F04
We keep getting this but can get around it.
You probably have a blocked pump/filter. If there is still water in the machine you will need to drain this first. So...
First try this. If it's finished the washing phase turn off the machine (rotate the dial to off then turn off at mains), leave for a min and turn on again at mains, then move dial to the rinse cycle.
If this works then it may clear the blockage for you. If not go to the bits below.
1. Remove the covering from the bottom RHS of the machine
2. There is a small black hose. Pull out and place in suitable container/bucket then unplug the end.
3. Will take quite a while to remove all the water. (Tip - once water is well below the window level unlock door and remove washing).
4. Once all water removed replace hose top and unscrew anticlockwise the white holder to the right of the hose. Make sure you have a towel handy to mop up any excess water.
5. Remove and clean all junk from it under a tap.
6. Look and see inside hole if any debris wool/cotton etc is blocking impeller and remove if necessary.
7. Replace holder.
et voila it should work again!
If not you have probably have a blockage somewhere in the pipe inside the machine. Sorry can't help with that one.
Apr 30, 2008 | Bosch Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
1,362 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
