Question about Troy Bilt 5.5hp Self Propelled Mower
Electric starter won't engage with the engine.
I have a Troy-Bilt Model 5521 Squall Snow Thrower that is three years old and used only a couple of times. The last time I went to use it the electric starter would spin but wouldn't engage with the engine. The engine does start with the pull rope although. I would also like to note that the Tecumseh Owners Manual provided with the snow thrower mentions to operate the starter for a few seconds while the engine is running before short term storage to avoid possible freeze up of starter and that this will not harm the starter or engine. I tried this and the starter would not operate at all. I am only mentioning this point because it seems as odd to me as the starter malfunction. The snow thrower is garaged and dry before several attempts have been made to get the starter to engage with the engine. What is likely causing this problem? Your answer will be greatly appreciated! Thank you!
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
  • greazydude Dec 22, 2008
    This system doesn't have a battery. There is a small induction magnet on the fly wheel that makes a spark each time the fly wheel turns.
  • 211 Answers
Hi
Disassembly the starter and ceck the starter housing,the armature,the end cover(with brushes and springs) and pinion gear.Also check the wires.Charge the baterry.
best regards savumihai71
3 Suggested Answers
  • 299 Answers
SOURCE: changing oil in a troy bilt squall 5521
To change oil in a lawn mower you will need to acquire a fluid evacuation pump. Remove the dipstick and with the pump evacuate the old oil into a suitable container. Check your owners manual to determine how much oil to put in DO NOT overfill or the mower will not work. Make sure the old oil gets recycled.
Posted on Oct 27, 2009
  • 173 Answers
SOURCE: How do I change the
There should be a plug at the end of the oil fill tube or its under the mower by the blade.clean the bottom of the motor and you will find a plug with a square head that a 3/8 drive rachet and extension will fit into.summer time use sae-30.
Posted on Dec 13, 2010
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
Electric start on Troy Bilt 21" single stage snow blower doesn't work. Recoil starter does. Electric start worked last year, but today, nothing. All cords good, power, etc.
The starter could be bad. Remove starter and see if it will turn over when 120v is applied.Check the wires to starter first! Good-Day!
Nov 16, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
How do I drain the oil from my Troy bilt 2100 squall snow blower so I can change the oil?
You need to remove the lower panel to access the engine. In the engine blow-out, the oil drain plug is numbered 77 (bottom of the crank case).
25256884-5livr0uqynklw3svefpqfefw-2-0.png 25256884-5livr0uqynklw3svefpqfefw-2-2.png
Oct 26, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
How do I change the oil on my Troy - Bilt squall 5521 ? Which oli weight do I use ?
Dec 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Changing oil in a troy bilt squall 5521
Oct 27, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
1,853 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
