Question about Toshiba Televison & Video
52HMX95 bulbs burning out too frequently
I purchased a toshiba 52hmx95 on 02/18/06.I am now on my third dlp lamp and am highly disappointed in this tv. The first lamp went out in May of 2006 only three months after the purchase. The second lamp lasted a little longer though not nearly as long as Toshiba projected. The first lamp was replaced by Toshiba but I had to purchase the second lamp.Posting Date Trans Date Type Description Expense Category Amount2/20/2008 2/20/2008 Payment ACH PMT - THANK YOU Miscellaneous -2/3/2008 1/31/2008 Purchase DLP LAMPS Household $176.00 The above shows when I purchased the second lamp. The serial number for my tv is 26403675. I am of the opinion that Toshiba should send me a bulb to replace the second bulb that burned out. In the event Toshiba doesn't replace the bulb, I can assure you that you will have lost a customer. I also have a 32"toshiba lcd and a toshiba vcr/dvd player. So I have been a good customer for Toshiba and expect the same in return.Terry Gillespie608 E Butler RdMauldin SC 29662 pportt@charter.net--------------------------------------------------------------------------------------
4 Suggested Answers
  • 50 Answers
SOURCE: toshiba 52hmx95 dlp
Take off the back, and take out screws holding in the light engine. Look at new light engine, and the old one you will have to take off a couple of things that your new engine wont come with. It is very easy to change. Any questions please ask.
Posted on Feb 14, 2008
ginko
  • 19396 Answers
SOURCE: Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Posted on Sep 02, 2008
hardrocko
  • 1476 Answers
SOURCE: toshiba 52hmx95 dlp tv. took
maxie99,
Fan is available at https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6475656&smodel=52HM95 for about $80.00. Replacement should be as simple as unplugging the fan cord and removing a couple screws to remove. Do the work with the unit unplugged from the wall. Reverse the procedure to install the new unit.
Thanks for using FixYa and the great rating.
hardrocko
Posted on Oct 19, 2010
62HM 95 TOSHIBA. HAD THE PICTURE JUST GO BLACK THE OTHER NIGHT. I HAD A LAMP FOR IT GIVEN TO ME BY A BUDDY IT MAY BE A USED ONE NOT SURE. REPLACED BULB TV CAME BACK ON BUT PICTURE IS TO DIM TO WATCH. DONT...
These Toshiba DLP's were lemons.
There was a class action lawsuit in the US and Toshiba were forced to issue a recall on the lamps. Toshiba replaced the first lamp for free but when the lamps are burning out every 6 months at a replacement cost of $200 these tv's are expensive to run.
Sounds to me like the light engine has failed. This will probably be a $800-$1000 repair.
Scrap it and take the hit.
Nov 01, 2010 | Toshiba 62HM95 62" DLP HDTV
When I trun on the tv there is vertical lines. If I unplug the tv it resets and is ok for a will. Now it blew the bulb again third time.
I think you have a issue with your light engine and you need to replace it to be honest with you this part runs from $250dls - $350dls check this link out
Toshiba got a lawsuit
http://www.avrev.com/home-theater-rear-projection-hdtvs/dlp-rear-projection-hdtvs/toshiba-ordered-to-pay-out-in-dlp-lamp-lawsuit.html
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!
Oct 26, 2010 | Toshiba 65HM167 65" Projection Television
Hi: My Toshiba starting showing the symptoms (as it has in the past) that it needed a new bulb. The red light comes on, is steady, but then the green light comes on and flickers. I have now put in 2 new...
I think that you have a problem with your ballast board this is the power source to the lamp if for any reason it starts to wear out or weak it will not be able to turn on your lamp check this link out it is about Toshiba lawsuit
Sep 21, 2010 | Toshiba 62HM95 62" DLP HDTV
Well...it will be about 5 years now with this tv....2nd bulb....was 2,000......ends up costing 2250....and counting...id buy another tv ....but to buy a bulb is simply cheaper....short end
I can't believe a lamp would cost that much. I service LCD and DLP projectors and the cost of lamp range between 250 to 500 max. Lamps will lose alot of life if they are turned on and off alot. The mfg's rate the life of a lamp if it is turned on and remain on till they burn out. THe lamp is given a high voltage when they start. This cuts the life down. Try searching for lamps to see if you can find a cheaper price online.
Feb 09, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba 62; DLP 720P- Alot more red and green
You have probably have installed the wrong lamp or you installed a third party/off brand Lamp. If that is the case anything other than a Factory replacement Lamp will have a different color temprature. Install a Lamp that is listed from the manufacture.
Jul 14, 2009 | Samsung DLP HL-P5663W 56" TV
What are the blinking light codes on a toshiba dlp meAn?
90% of the time your lamp needs replacing.( DLP sets only )
Jun 18, 2009 | Toshiba Televison & Video
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Hewitt Packard high definition DLP tv Product #EX543AA#ABA need part, hp no longer carries them.
I have a brand new L2114a lamp for sale. I paid 299 plus shipping on ebay but it turned out to be the wrong one (despite what the manual says). I ordered the correct one I needed from HP. I am willing to part with it for 200. I can send pictures of the lamp and the box and the reciept. This is a BRAND NEW LAMP.
This lamp works in the following televisions and replaces the lamps listed below:
HP Pavilion md5020n 50-inch High Definition DLP TV L1735A
HP Pavilion md5820n 58-inch High Definition DLP TV L1736A
HP Pavilion md6580n 65-inch High Definition DLP TV L1737A
HP Pavilion md5880n 58-inch High Definition DLP TV L1798A
Jan 28, 2008 | Televison & Video
Projector Lamps for the Toshiba TDP-MT8 DLP
Have you contacted Toshiba? They will sell you a new fan. It is possible the power supply has a problem. Bulbs usually have a 90 day warranty. Contact where you bought the bulb. Prices are dropping rapidly for new projectors. Yoiu can buy a new oen for under 500.00.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 07, 2007 | Toshiba TDP-MT8 DLP High Definition Home...
Televison & Video Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
