Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Virtual Memory Minimum Too Low
I get an error message just before the logon screen that says Virtual memory minimum Too Low. I get the option to click ok. So I click OK and then the screen stays all black. The mouse pointer still moves around. How can I solve this. I can't even log on the machine in safe mode.
  • 52 Answers
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Posted on Dec 22, 2008
Virtual memory low
Go to my computer Properties -> Advanced Tab -> in Performace Click Settings-> Click Adjust for besr performance-> Apply->OK ... Try it...
Remove all temporary files...
Jul 08, 2013 | Sony VAIO Computers & Internet
My pc is running low on virtual memory when i use the internet
In general, you want to set your minimum virtual memory to about 3 times the total amount of memory installed in the machine.(3072MB for each gig of ram) The maximum should be 4096 more than the minimum setting.
To check this, right-click on "My Computer" and choose "Properties". Click on the "Advanced" tab and click the "Settings" button in the "Performance" section. On the "Performance Options" panel, click the "Advanced" tab. The virtual memory button is at the bottom (on xp machines). Selcect "custom" and then set the values according to how much ram you have in the machine. For more, check here.
http://www.thermwood.com/forums/viewtopic.php?f=3&t=897&hilit=virtual+memory
Oct 08, 2011 | Computers & Internet
Error message Low on virtual memory
Virtual Memory is used by the operating system as an extension to the Random Access Memory (RAM). When the RAM does not have enough space to accommodate the entire running program, the inactive parts of that program are temporarily shifted to the Virtual Memory. These parts are then swapped back into the RAM as and when needed. If the Virtual Memory set on your system is not enough for the computer operations to run smoothly, then you will get the "Virtual Memory Is Too Low" error message.If operating system is xp then this problem can be easily overcome by increasing the Virtual Memory size.This is how you can do it by following instrutions:
  1. Click on "Start" and then click on "Control Panel.
  2. Double-click on the "System" icon in the Control Panel.
  3. Click on the "Advanced" tab in the System Properties dialog box.
  4. Click on the "Settings" button below Performance.
  5. Click on the "Advanced" tab in the Performance Options dialog box.
  6. Click on the "Change" button below Virtual memory.
  7. Click on a drive_letter below "Drive [Volume Label]" in the Virtual Memory dialog box.
  8. Click on the "Custom size" option.
  9. Click in the "Initial size (MB)" text box and type a larger value (for example, 600).
  10. Click in the "Maximum size (MB)" text box, and type a larger value (for example, 1500).
  11. Click on the "Set" button. Similarly change the Virtual Memory on other drives.
  12. Click on "OK" and then restart your computer.
Apr 07, 2010 | Microsoft Windows XP Professional SP2
When I am playing XENO Assault II, it crashes and says virtual Memory error, I have a 256MB ATI Radeon X1300 Pro video card, and 2 gigs of memory. I was thinking about upgrading my processor to a Intel®...
Virtual memory is actually part of a computer's physical memory that comes in the form of memory chips or RAMs. So what right? Well, it is a necessary evil and in order for your computer to run numerous programs simultaneously (at the same time), it looks for areas of RAM (Random Access Memory) that is not currently being used and it copies files over to what is called page files. This is simply a process that allows RAM to free up space and subsequently load new or additional applications. This process is technically called thrashing and the result of it can cause the computer to react somewhat slower in its functions. However, when the computer hard drive (virtual memory) which is slower than the installed memory chips wants to correct itself, it has to constantly swap between the RAM and the hard disk drive.
What Causes These Windows Out of Virtual Memory Error Messages?
  1. The first and foremost probability is that the Windows operating platform page file maximum file size - is too small. You may think your system has a large amount of virtual memory (RAM) because the person that sold you the computer told you so. Well, this may or may not be the actuality if page files are set too low and you are getting error messages. Obviously if you are getting an error message page files are being maxed out and something needs to be changed to correct the situation.
  2. There could have been a power failure or, you shut your computer off incorrectly which led to a file or files becoming corrupted and this subsequent virtual memory message beginning to haunt you. So the two lessons learned here is to have a back-up source of power and, to always get into the practice of properly shutting down Windows via the start button where it reads "Turn off computer" in lieu of simply hitting the power off button.
Okay, so now that you have an idea of what virtual memory is, system thrashing and how it suddenly became an irritant error message, what can be done to make things right in your Windows operating platform?
Realize that although Windows automatically sets both minimum (the amount of RAM installed on your PC + 300 MB) and maximum (3 times the amount of installed RAM) to its page file sizes if you do get that virtual memory error message - then you can do the following steps to increase these minimum and maximum page file sizes;
Re-Setting Windows 2000 virtual page file sizes
  1. Right-click My Computer , and than click Properties
  2. Within System Properties menu box, click Advanced
  3. Click Performance Options . Within this pane (Virtual Memory), click Change to increase the paging file. Take special note that your Windows 2000 minimal value requires at least 126 MB for debugging.
  4. After you change (increase) the setting, click Set, and than click OK to the following message you will receive;
  5. The changes you have made require you to restart your computer before they can take effect.
  6. Click OK to close the Performance Options menu, and than click OK to close the Systems Properties menu.
  7. When prompted to restart your computer, simply respond to Yes
Re-Setting Windows XP virtual page file sizes
  1. Click Start , right click My Computer, and than click Properties
  2. In the System Properties menu box, click the Advanced tab.
  3. In the Performance menu, click Settings
  4. In the Performance Options menu, click upon the Advanced tab.
  5. In the Virtual Memory menu, click Change
  6. Change the Initial and Maximum Value Sizes to a higher value, click Set and than click OK
  7. Click OK to close Performance Options menu, and finally OK to close the Systems Properties menu
Re-Setting Windows Vista virtual page file sizes .
  1. Click on the Start button, click Control Panel, click System and Maintenance, and then click System
  2. In the left pane, click Advanced system settings. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. On the Advanced menu, under Performance, click Settings
  4. Click the Advanced tab, and then, under Virtual memory menu, click Change
  5. Clear the Automatically manage paging file size for all drives check box.
  6. Under Drive [Volume Label] , click the drive that contains the paging file you want to change.
A CPU upgrade would be a good idea, the core 2 duo is a superb processor.
Also a bit more ram perhaps another gig or two? and maybe a 512mb graphics cards would be good for gaming.
perhaps a better power supply too as E520 was not really designed for gaming.
Feb 24, 2009 | Dell Dimension E520 PC Desktop
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Virtual Memory error
Dear
Right click on My Computer icon .. go to Properties->Advanced->Setting->advanced->Change..
THan Select Drive go to Custum Size Fill Minimum an Meximum virtual ram size remember u fill double ammount to ur actual ram size like 512-1024
Click Set ok  and restat ur pc
Oct 19, 2008 | Computers & Internet
Nintendo DS lite game card
there several steps like these....
may be the virtual memory is low.... you trying increasing virtual memory..
this can be done by following
1. go 2 control panel,system,advanced tab
2. in performance option click settings
3.go to advanced
4. go to virtual memory option there click change select your operating system drive and increase the virtual memory minimum for 700 and max to 900... give ok
and then have check...
if same problem persists may be ram u r using is low upgrade your ram to atleast 512mb ram
or
may be you are using the old version of directx... install latest version of directx ( atleast you install directx9.0c)
or may be operating system problem(may be due virus attack system files have became unstable) try reinstalling it...
Jan 16, 2008 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
474 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
