Question about KitchenAid KCMS145J Microwave Oven
Kitchenaid ykcms135h intermittent problem.
Works fine 80% of the time. Rest of the time when I start it, after few sec (10 - 30 sec) display will start funny (scrambled characters) and some times I hear arching. At this point unable to stop the microwave using key pad and need to open the door to stop it. Only way to start it again is to unplug it and plug it again after few sec. I opened the microwave and didn't see any burned parts. Looks very clean inside. Please shed some light on this problem. Thanks, Mat.
  • Mat Than Apr 08, 2007
    I found the problem. It was the Magnetron antenna seal got burned because of arching. The Magnetron top clamps got loosen and this caused the arching. There is a screw hole for the Magnetron (Toshiba 2M248J(GS)) on the top and the botttom but no screws (they clamed the cornres, but no screws were in place). I am not sure why there are no screws although there are screw holes in the magnetron. The new o ne I bought also came without the screws.
  • KitchenAid Master
  • 9,098 Answers
Exactly! There is a wire mesh gasket sealing the mag where it goes into the waveguide mounting hole. If that seal is not tight, microwaves escape, causing bizarre electrical interference. Sorry I didn't see before the bogus answer above got posted - I've been tied up and away from the PC.
Posted on Apr 10, 2007
    Genius:
  • 1,074 Answers
If you are not a tech kindly take your microwave to a tech for repairs.the diodes or the cap high voltage is your culprit.good luck.
Posted on Apr 04, 2007
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Door open button won't work on KitchenAid microwave model YKCMS135H
Page 3 of the exploded view here shows the door open parts 24510L and 250201 (or 23551B if your full model number is YKCMS135HSS).
What look like part numbers seem to be reference numbers.
For further help you will need to contact Kitchenaid Canada here.
Sep 05, 2012 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave makes a thumping sound then no heat
sounds like the hi voltage diode or capacitor are intermittant, the thump is the transformer drawing current when the magnetron tube calls for hi voltage to operate, you will see the lights dim slightly every time it cycles the mag tube for heat
Oct 07, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The microwave turns on radomly
call kitchenaid
you will need a touch pad and control... touchpad is shoring out causing it to turn on...
hope it helps
Sep 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
F2 Message Code
good day,
hope this link below will solve your problem.
kitchen appliances
Jul 03, 2009 | KitchenAid KHMS155L Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
Kitchenaid built in Microwave model YKHMS155LSS-0 Starts by itself, displays PAN, beeps intermittently and sometimes displays an F1 error
Dougmcduff have you resolved this problem with you kitchenaid microwave turning on periodically??? I have the exact same problem. Any solutions? I called Kitchaide and no help there.
Mar 10, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave Shuts off...
It sounds like you may have a loose fuse holder or an intermittent part such as one of the thermostats, such as the one mounted on the magnetron.
One thing to try is to cook on the lowest power setting or defrost to see if it runs longer or fails more quickly.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 06, 2008 | KitchenAid KHHS179LSS Convection /...
LG 1925 Microwave suddenly stopped cooking, other functions work fine!
What you said about the the clock leads me to suggest that you first unplug it for a few minutes then plug it back in. It may just need a good reset. If you don't have your owner's manual you can download one here: http://www.lge.com/support/manual.jsp The mention of odor concerns me. It may just be a bit of food or grease on the waveguide cover, which is a small sheet or panel on the wall or ceiling of the cooking cavity, but it may indicate the failure of a part in the high voltage section. You may have an intermittent door switch. You can see some of my other responses for info on how to get our important text file that helps you diagnose and repair door switches and gives important safety tips.
Dec 10, 2006 | LG LMV1925 Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
229 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
