Question about Apple iPod MP3 Player
Won't hold charge
I have a fifth generation Apple ipod 30GB. I have never had problems with it before, but now all of a sudden it won't charge. I have tried letting the battery completely die and then charging it, but that didn't work. Apple's support site said that it may be the cable I was using may have been faulty so I used a friend's and that didn't work either. It says it is charging, but if I let it "charge" for hours on end and check on it, I find that it hasn't charged a bit. Please help!
  • 8 more comments
  • goosie Nov 05, 2007
    have 20gb model m9787LL, it won't hold charge, usb connection not recognised by PC, wall charger switches it on and charges but it won't hold charge.
  • gosse30 Jul 16, 2008
    i had my ipod for 7 months and now it wont hold a charge even if i got it in my charging dock for days.
  • lisanoe Jul 24, 2008
    Charge for hours or all nite and when unplugged it is not charges at all??
    What is wrong??
    HELP
  • bad_samantha Aug 16, 2008
    My 80G video ipod won't turn on unless it is plugged into a power source. When i plug it up it says charging but it lies!!!!! I have tried different cables, different charging methods, beating it, yelling at it, and trying voodoo on it but nothing has worked. The whole point of having a portable mp3 player is it's portability!!!!! The only solution I have found that might work is buying a new battery from some random website and replacing it. That's great but there has got to be something else i can do right?......
  • Anonymous Aug 26, 2008
    Same problem, I recently replaced my ipod´s battery with a 850 mAh. It was working just fine. After this, I broke my display so I replaced it with a new one. After replacing the display everything works fine except for the fact that ipod would say "charged" and as soon as i disconect it it goes death. After this I reseated the battery connections, closed it and now It does not charge, I tried PC, MAC, and wall charger. When I connect to wall charger ipod works just fine and says "charging" but as soon as I disconect it is completly death. I reset it, left it overnight charging, I reset it again, put it in disk mode, and still same problem. I dont believe it is the battery because I bought it last month. I might open it again and check the battery connections... If someone knows a solution please let me know.
  • metallicarlo Aug 26, 2008
  • eLemon Sep 19, 2008
    Same thing here. I have tried multiple batteries, and Ive found that if you take a charged battery and put it in, it works until the battery runs out. This leads me to believe it has something to do with the charging mechanism. I dont really know what about it is faulty though, mine looks fine. If anyone has any info on this it would be appreciated!
    Yep, mine wont hold a charge either. Ive tried multiple batteries and figured out that if you put in a charged one, it works up until the battery runs out. It has to be either a problem with a connection or the charging mechanism. Any info would be greatly appreciated.
  • Anonymous Nov 20, 2008
    my ipod wont charge and says very low battery also while plugged in to the computer it says usb device malfunctioned
    i bought a new battery and installed it and it worked until i let the battery die now it wont charge back up
    Problem Solver:
  • 8 Answers
Try geting your hands on a ipod usb wall charger, this will charge it directly on to a wall
Posted on Apr 09, 2007
REBOOT IPOD
which model ipod they all have different ways to reset usually through iTunes
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Hope this helps.
Jan 20, 2013 | Apple iPod Audio Players & Recorders
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
My four generation classic 30gb ipod not able to switch on
First off make sure it is charged up,try plugging up to wall charger/or usb charger.If thats not problem & still wont turn on.you have to reset it by holding the TOP(up) button and the CENTER button at the same time to reset it. Hold both down until you see the apple logo appear & loading as soon as it loads up(give it a min) all will fine then & should play normally.
Feb 01, 2010 | Apple iPod MP3 Player
I have a apple iPod,fifth generation,30GB.My question is how do you delete songs or Album form iPod.
You will need to connect it to itunes and then delete from the ipod while it is connected.
If your ipod is set to manually manage music and videos then you can manually select songs and albums and hit delete. This may take a while. Use the search feature to scroll quickly.
If your ipod is set to auto sync then all you need to do is uncheck the songs, playlists and albums from synchronizing. It will remove them from your ipod.
Nov 29, 2009 | Apple iPod MA446LL/A MP3 Player
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: http://support.apple.com/kb/HT1353#ipodfifth2 which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
Ipod shows its connected when not plugged in
Take the hold switch and turn it on, then off. After this press the center button along with the Play/Pause button and it should reset your iPod. This may solve the problem.
Jul 27, 2008 | Apple iPod MA446LL/A MP3 Player
My 30gb ipod is frozen
have you tryed the five rs?
sounds like a hardware problem, I would contact apple, or your dealer, or a local professional for repairs.
Apr 05, 2008 | Apple iPod MA446LL/A MP3 Player
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 06, 2007 | Apple iPod MA446LL/A MP3 Player
Ipod 30 gb fifth genertioan not play songs
Hi ali001,
You could try resetting the iPod, I don't remember off hand which combination of buttons you have to press but there will be help for this on Apple's website...
Please rate if at all useful, thanks!
Dec 04, 2007 | Apple iPod nano
Apple iPod MP3 Player Logo
205 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Mohamed Ismail
Mohamed Ismail
woodzowl307
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
