Pantech Matrix Pro C820 Cell Phone Logo
kerrilynn Posted on Aug 24, 2012
Cannot connect to computer - Pantech Matrix Pro C820 Cell Phone
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Aug 25, 2012
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
13938
Points
33
With your cord?, make sure your using the correct cord and are you plugging it into the right place (usb port)?
tip
How To Connect to home computer from Another Location
<p>Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as if you were actually sitting in front of your home computer.<br />Follow the given steps to configure your computer to connect with remote computers: <br />To use this feature, you will need to be logged into your computer with administrative rights. Make sure both computers are connected to the internet. <br />First you have to configure the host computer to allow users to connect to it remotely. On the host computer, right click on "My computer" and click on Properties option.<br />Under the Remote tab, select the option "Allow users to connect remotely to<b> </b>this computer" and click Ok button.<br />Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).Start--Run--type "CMD" then hit enter for command prompt.<br />Now make a connection on remote or client computer, click on Start button, go to All Programs&gt; Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.<br />Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer. If your username and password is correct then a remote desktop windows will appear. <br />
on Jul 11, 2011 • Computers & Internet
tip
How to Connect a Windows 7 Computer to a Windows XP
Even though Windows XP and 7 are different versions of Windows, you can still connect a computer running Windows 7 to an XP computer using Remote Desktop Connection. Remote Desktop Connection is a utility in Windows that allows you to log in to a remote computer directly from your computer's desktop. However, before you can use the utility on your Windows 7 computer, you must enable it on the Windows XP computer. To connect to the Windows XP computer, you also need to know the XP computer's name.
Instructions
Enable Remote Desktop on the Windows XP Computer
  1. Click "Start" on the Windows XP computer, and then right-click "My Computer."
  2. Click "Properties" from the pop-up menu.
  3. Click the "Remote" tab, and then click the "Allow Users to Connect Remotely to This Computer" check box.
  4. Click "OK" to confirm the change when prompted on the pop-up window. Click "OK" on the open windows to close them.
Connect to the Windows XP Computer
  1. Click "Start" on the Windows 7 computer, and then type "Remote Desktop Connection" in the search box. Press "Enter."
  2. Click "Remote Desktop Connection" from the results list.
  3. Type the name of the XP computer in the "Computer" box, and then click "Connect" to connect to the XP computer.
References
  • ( Microsoft Support ) How to Use the Remote Desktop Feature of Windows XP Professional
  • !!!!CLICK HERE!!!!!
  • ( Microsoft Windows ) Connect to Another Computer Using Remote Desktop Connection
  • ( Microsoft Windows ) Remote Desktop Connection: Frequently Asked Questions
*please leave a rating if this information is helpful and beneficial to you.
Regards
MultilinkEnt.
on Jun 05, 2011 • Computers & Internet
2answers
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
tip
Connect your home computer from Remote location.
You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
Follow the given steps to configure your computer to connect remote computer: To use this feature, you will need to be logged into your computer with administrative rights.
-To perform this task, first make sure your both computers are connected to the internet.
-First you have to configure the host computer that allows the users to connect it remotely. On the host computer, right click on "My computer" and click on Properties option.Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
-Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
-Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
-If your username and password is correct then a remote desktop windows will appear.
Good luck.
on Apr 15, 2010 • Computers & Internet
tip
How to connect your home computer from Remote location?
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as you were running actually sitting in front of home computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
my_computer_properties.jpg Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
remote_desktop.gif Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).
remote_dialogbox.jpg Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer.
remote_desktop_connection.jpg If your username and password is correct then a remote desktop windows will appear.
on Dec 03, 2009 • Computers & Internet
Connecting my computer directly to konica 8020
You can hook the copier directly to your computer using a USB cable.  You can purchase one at any computer store.
Limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
You can check this site for more information
http://www.annoyances.org/exec/show/ics_xp
You can try to connect the two computers first without the internet connection.
Example : PC A 192.168.0.2
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B 192.168.0.3
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
1.
Choose Control Panel from the Start menu.
2.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
http://www.homenethelp.com/connection-sharing.asp
http://practicallynetworked.com/sharing/xp_ics/
2helpful
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Top Pantech Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
