Question about iLO (2 GB) MP3 Player
Ilo 1G wont turn on
I push the power button and it says searching files then sorting files then it turns off and starts over
  • johnscott Jan 18, 2008
    I have the same problem; I turn it on and after the logo screen it says "searching files.... 20%" and then goes back to the logo screen and does it all over again. I have deleted the songs and it and even reformatted the device but and still getting the same error.
  • 8,596 Answers
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on Jul 06, 2008
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
Won't play
Sounds like the download is corrupt, delete data and download a single known good mp3 file and retest
Nov 07, 2007 | iLO (2 GB) MP3 Player
Starts buy restarts after it gets to 80% sorting.
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 04, 2008 | iLO (2 GB) MP3 Player
ILO wont start all the way
Reset
Dec 25, 2007 | iLO (2 GB) MP3 Player
ILO wont work
One of two things..try a new battery...or it's possible that your button lock button is in the lock position ( look under the power button make sure it is pushed up)
Dec 24, 2007 | iLO (2 GB) MP3 Player
My Ilo MP3 will turn on but will only turn off after loading.
Sep 24, 2007 | iLO (2 GB) MP3 Player
Sorting... sorting...
If the player allows you to add music on it via USB as a Removable Disk, then copy all the music off the player onto your computer and then format the MP3 player by right clicking it in "My Computer" and going to "Format...". Start it up without music and see how it goes, if it doesn't turn itself off, fill it with a little bit of music, then a little more until you either put your music back on, or until it screws up again. Good luck!
Sep 05, 2007 | iLO (2 GB) MP3 Player
TV WONT TURN ON
try pressing the channel or volume buttons. They turn on the tv as well. Maybe the the remotes might cooperate with the tv.
Jul 22, 2007 | iLO 3200 32 in. LCD Television
Ilo logo, search, sort, repeat
May 05, 2007 | iLO (2 GB) MP3 Player
Starting over and over again
This very thing happened to me, it will say ILO searching updating and sorting, and it will say this over and over and over. I found out that there is a certain file called an XML DOCUMENT and it is named "WMPINFO" and i found this on my computer and copied it to my ilo 1gb mp3 player and for me it fixed my problem and i could listen to my music again. Aparently this is the file to make it run or something, if you need this file I can email it to you my email is skidmarker@yahoo.com When you open the XML DOCUMENT with XML EDITOR it will read: -
Apr 14, 2007 | iLO MP3 Player
iLO (2 GB) MP3 Player Logo
32 people viewed this question
Top iLO Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Allen Benge
Level 1 Expert
Jon Piercy
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
