I just bought a dell 1525 used that has a bios password and I can get in, give number as C088PF1-595B Can anyone help?
Email me for *ANY* BIOS, HDD, And Admin passes!
[email protected]
Open the back panel of your your laptop and try to find out the Cmos batter inside it, remove it for atleat 2-3mins and put it back, or may find written RTC on the board with two small dot on it, just take screw drive and touch both the dot for a while. by doing this your password must have gone. But remember to remove your backup battery and adapter before doing all this.
SOURCE: dell 1525 Bios Lock Problem
Call or chat with the Dell technical support and they can provide you the Master reset password free of charge.
SOURCE: Dell vostro 1500 has BIOS PASSWORD
It sounds like you are prompted to enter bios password. Call dell tech support and they will generate unlosk code for you.
SOURCE: Dell inspiron 1300 bios password
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: how do I reset bios password on a used dell 710m
I have the same problem. but how to take out the cmos chip? If we don`t know what chip is.
Please i have been looking for a answer in the web. and the people from dell don`t give us any chance.
Please we neeeeeeeed help.
