Question about Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G
Audio how do I make the audio work. I don't have extra speakers, just whats on the monitor
    President:
  • 1,179 Answers
Are there speakers on the monitor? If it has speakers then they need to be connected to the speaker output[s] on your soundcard. Usually with dell it is colorcoded green on the back of your computer. Hope this helps.
Posted on Dec 21, 2008
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
I cannot hear any sound from my Dell monitor 1702FP. Are there speakers installed within the monitor?. VGA cable is connected. When I use a spare monitor using the VGA cable the sound is loud and clear. ...
The Dell 1702FP doesn't have speakers.The specs of the Dell 1702FP are available here: http://support.dell.com/support/edocs/monitors/1702fp/en/specs.htm . (BTW neither does the Dell 1704FPT.) However, some Dell monitors can have a sound bar (speaker set-up) mounted on the monitor.
VGA cables don't carry sound. Check if a second cable (an audio patch cable is connected to the computer and the second monitor). (There are some cables that actually bundle the 3.5 mm patch cable with the video cable for convenience. (I've seen a number of DVI cables with that bundle option.) The plugs will separate into separate units at each end.
Other monitors do have speakers built in - look for a 3.5 mm audio input jack with the rest of the input connections on your monitor. There are some monitors that accept an HDMI input with a 3.5 mm audio out jack; these monitors don't have speakers and thus are enabling a daisy chain to connect the speakers to the monitor. So you do need to be careful and look for the audio in label.
You can attach a set of speakers to your computer using the audio out (look for a lime green 3.5 mm jack on the back of a desktop). For laptops or to use the front audio ports, look for a headphone jack.
I hope this helps. Please add a comment with more information about your monitor and computer for additional assistance.
Mar 11, 2012 | Computers & Internet
I just hooked up an AOC monitor to two computers. Sound is working on one but not working on my HP Pavilion. How do I resolve that? I don't have any extra speakers.
The sound goes out of the computer to a set of speakers. If the monitor has speakers built into it, then the sound comes out of them. Each computer must have a connection to the sound card (the little green hole) to speakers. If you want sound from the second computer, unplug the sound cable from the one computer and plug it into the other one.
Sep 15, 2011 | AOC Monitor
My monitor speakers don't work, but I see an extra connection that has no wires attached is that for the for the speakers??
The monitor should have a wire that goes to the green colored input plug on the back of the PC.
Sep 07, 2011 | Soyo DYLM2286 Monitor
I have lost my speakers on the monitor. Using Microsoft XP, they were working but now they are not. Did some driver updates then lost the sound on the monitor. Checking the control panel indicates that...
Sounds like you've lost audio output from the sound card. Unplug the audio cable from the sound card and plug in a set of ear buds or headphones. If you don't get any sound your driver's not working. Try reinstalling the old driver.
Aug 08, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
I need to connect my old speakers to my new Samsung monitor. No instructions in manual. thanks, barb
You don't connect speakers to the monitor, you connect it to the tower of the computer. If I'm not understanding your question right then please be more specific. If your monitor has speakers, you connect the audio cord to the tower then to the monitor or vise versa.
Jul 29, 2011 | Samsung Syncmaster 940BW LCD Monitor
I have an HP Pavilion M50 monitor with polk audio speakers. I don't have the original power supply for the speakers. I have tried several 9v power adapters and none of them seem to work. What power...
if it requires 9volts then it should be good. no problem with your windows vista. its just that your speaker wont power on. maybe you got to have the wrong polarity. try to recorrect the polarity. i mean put the negative to possitive and positive to negative. if the wire has a color put the black to red and red to black.
Jul 11, 2011 | Polk Audio AMR50 Computer Speakers
No sound from monitor
Yes you need speakers, your monitor doesn't have any inbuilt speakers
Jun 26, 2009 | Acer X193W LCD Monitor
No audio from monitor
you don`t need a driver for the monitor sounds like the sound card driver
Mar 29, 2008 | Audio Players & Recorders
Dell Inspiron 530s Desktop Computer (ddcwfa2_5) IntelPentium dual-core processor E2160 (1MB L2,1.80G Logo
94 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
