Question about Dell E771p 17" CRT Monitor
Problem with my Dell E771mm 17 in.CRT monitor
I got a Dell E771mm 17 in.CRT. The screen is narrowing in on both sides in a curve towards the center of the screen.I have this monitor for 1 year and 3 months. The store i bought it from said they cant do anything as it is a refurbish monitor and is sell with only 30 days warranty; all this I'm just finding out. Yesterday when the problem start it give off a little sound before the screen got small. What can be the problem?
  • 2 more comments
  • Samarcia Munroe
    Samarcia Munroe Apr 04, 2007
    The arch is in the center and I'm in jamaica. Can it b repair?
  • Samarcia Munroe
    Samarcia Munroe Apr 05, 2007
    So do u think it is a good idea to buy a new monitor instead of repairing this 1. I get a new monitor in my country from $130US - 450US and that is from 14' monitors to 21' crt the LCD monitors is very expensive to buy.
  • Anonymous Sep 26, 2008
    SCREEN SRINKED FROM VERT. SIDES AND CURLED. WHAN I TRY KNOCK A SINK TRANSISTOR IT BECAME NORMAL FOR SHORT PERIOD OF TIME.
  • Anonymous Jan 24, 2009
    i have same problem with samsung 753s sync master ,i am tring to repair my own can u tell which all components should b replaced
  • 624 Answers
How far from the sides is the image? If it?s just an inch or two you can use the monitor adjustments to expand the image to the edge of the screen where it was previously. If its too far in then the only option is to have it repaired. You didn't mention where you are but in the US even a minor monitor repair that involves at tech opening the monitor is going to cost at least $45, perhaps more. That?s a lot of money for a monitor worth about $100 new so a new or used monitor may be a more cost effective option for you. Let us know if you have any other questions and please don't forget to rate this post.
Posted on Apr 04, 2007
  • tomj23 Apr 04, 2007
    That?s probably too much to adjust for using the monitory controls. As far as your question goes, yes it can be repaired by a qualified service technician OR someone with sufficient skills, tools and experience. This is beyond the typical user so you'll have to take it to the local TV repair shop. Be warned that they will probably charge more than 1/2 what the monitor is worth and would probably only warranty their work for a month or two..
Control menu is locked
Press the OSD button for 3-5minutes before it will be unloacked.
I accept donations for my free service Thankshttp://www.paypal.comsend it to paypal email: rpamular10@yahoo.com
Mar 13, 2012 | Dell E771MM 17" CRT Monitor
I have a dell monitor and I keep getting this notice that control menu is blocked. how can I resolve this?
For the E771MM, press and hold the OK button on the monitor for 15+ to toggle off the OSD lock. Holding the button turns on the OSD lock as well. The OK button is the rightmost of the control buttons (excluding the power button). This is a useful feature if a small child will be near the monitor or if the monitor is being used for demonstrations.
The user's manual for the Dell E771MM is here: http://support.dell.com/support/edocs/monitors/e771mm/English/index.htm .
I hope this helps.
Jul 01, 2011 | Dell E771MM 17" CRT Monitor
When the monitor (dell e771mm) is hooked up and the computer is turned on, the monitor goes right to a solid blue screen, no text, no error messages, i can manually control the monitor menu and it displays...
I do not think it is your monitor. Plug it into another working machine to see what it does. The result will tell you whether it is the monitor or the computer.
Sep 01, 2017 | Dell E771MM 17" CRT Monitor
My monitor's model is TX 78682 ,now the menu control is locked and I want o know how to unlock it?
try to press and hold the MENU button of your monitor for about 9 to 15 seconds to unlock it. hope this helps. feel free to rate the usefulness of the info
Mar 30, 2011 | Dell E771MM 17" CRT Monitor
How do I activate the web cam on the dell E771mm monitor?
There is no webcam on this monitor. It's a display device only, with speakers built in but that's all. Here is the user's guide on Dell's site with all the monitor information.
Oct 23, 2010 | Dell E771MM 17" CRT Monitor
What is the very small window at the top of the monitor case in the vary midle ?
r_gattis, If you see a small hole in it, you will need to speak into it because it's a microphone!!! Go to this link. http://support.dell.com/support/edocs/monitors/e771mm/English/quickref.pdf/
12fixlouie
May 25, 2010 | Dell E771MM 17" CRT Monitor
Screen curves in on the sides, what is the cause?
This effect is known as "pin cushion". There is an adjustment for it on the front of your monitor. Follow your monitor guide for instructions on accessing the correct buttons to make the adjustments.
Apr 19, 2010 | Dell E770P 17" CRT Monitor
Screen is distorted
hi there, Below the monitor, on the center are option button, you can explore that in adjusting your screen display. You can widen the display, or tweak it depending on the angle that you need to. Just press the center button and choose from the menu.
Oct 25, 2008 | Dell E771p 17" CRT Monitor
Monitor Problem
This is a duplicate post, click the following link to go to the active posting. http://www.fixya.com/support/t141063-problem_dell_e771mm_17_in_crt_monitor
Apr 04, 2007 | Dell E771MM 17" CRT Monitor
Monitor Problem
Dell E771p 17" CRT Monitor Logo
196 people viewed this question
Alun Cox
