What is the amperage for a T1Al 250Volt Fuse?? 11/4 x 1/4 for a Boston Acc. Subwoofer. I can't believe how difficult it is to find this info. Thanks Much,
  • 67 Answers
1-amp
Posted on Dec 23, 2008
Radio stopped working now dash lights stay on 09 focus
With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity, The dash lights stay on with headlamp switch off ?
Have checked the fuse's for the Radio ?
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Compact disc (CD)
  • Antenna
  • Battery junction box (BJB) fuse 11 (30A) (subwoofer amplifier)
  • Central junction box (CJB) fuse(s):
    • 31 (20A) (audio unit hot at all times)
    • 41 (7.5A) (audio unit hot in RUN/ACC) (early build)
    • 57 (7.5A) (audio unit hot in RUN/ACC) (late build)
    • 62 (7.5A) (audio unit hot in START)
  • Audio unit
  • Speakers
  • Subwoofer amplifier
Do you know where the central junction box Is ?
Pinpoint Test A: The Audio Unit Is Inoperative/Does Not Operate Correctly
Normal Operation The audio unit receives voltage at all times through circuit 29-MD15 (OG/BK), voltage in RUN/ACC through circuit 75-MD15 (YE/GN), and ground through circuit 91-MD15 (BK/GN). The audio unit is operational with the key in RUN or ACC.
    Possible Causes
  • Fuse
  • Circuit 29-MD15 (OG/BK) open
  • Circuit 75-DA4 (YE/GN) open
  • Circuit 75-MD15 (YE/GN) open
  • Circuit 91-MD15 (BK/GN) open
  • Audio unit
  • Can you pull the radio out , to check power and grounds at the radio connector's if fuse's are Ok .
Dec 30, 2016 | 2009 Ford Focus
Need the amp rating for the 12v power adapter on Boston BA635 speakers/subwoofer
The bigger the better. It will either get hot if it's not powerful enough, or work ok. The amperage isn't important. The voltage and polarity are. Worst case scenario is you will burn out the adapter if amperage is too low.
Feb 02, 2015 | Audio Players & Recorders
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
May 27, 2012 | Boston Acoustics SoundWare XS 5.1 Speaker...
LOST A CORD TO MY COMPUTER SPEAKER SYSTEM MICROMEDIA SYSTEM. SERIAL NUMBER IS PN7000596, EJ 0192668 O THE SUBWOOFER. TWO SMALL SPEAKERS CONNECT INTO SUBWOOFER. LOST ONE CORD. CAN I GET A...
They usually use pretty standard audio cords, you can probably just get a replacement at your local Radio Shack. The only one I would be worried about is if you lost the power cord....if that's the case you need to be sure if you buy a different one that the voltage is the same as required.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
I have a Boston Acoustics PV1000 that's getting no power but the fuse appears to be OK. What else could it be? thanks
I have the same problem. La Mars covers the factory repair for these. Their number is 712-546-1644. Have you fixed your problem yet ?
Mark
Nov 26, 2010 | Boston Acoustics PV1000 Subwoofer
How do i connect my boston acoustics pv800 subwoofer to my Harmon Kardon AVR 520 reciever?
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Jun 06, 2010 | Boston Acoustics PV800 Subwoofer
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP Home Edition 2002, Gateway FX400 Pentium (R) D CPU 2.8 DGhz, 2.8 Ghz 500MB RAM. Can I do...
I have a Boston Digital BA735 Subwoofer. I would like to connect it to my current system. I running on Microsoft XP, Dell Latitide 610.Can I do this? If so, do I need a different audio cable connector cord? Thanks
Nov 18, 2009 | Boston Acoustics BA735 Computer Speakers
124 people viewed this question
 Grubhead
Grubhead
