Question about RCA HD52W59 HDTV Projection Television
My RCA TV has a distorted picture.
The picture has green & red lines on top and the picture looks like 3D
  • 3 more comments
  • mikat52 Dec 21, 2008
    What is open Fuse FL231. Can I fix it myself?
    What and where is the flyback on my tv
    Thank you for your help, however, I still don't know what is these boards that you are talking about. I need to take the back off, and then will I see anything that tells me the SSB board or power/deflectiohn. I am sorry, I am not trying to be difficult, just I am frustrated around Xmas time and I can't afford to have a repair man. I am hoping I can do this, and with your help sounds like I can.
  • MILUS98 Dec 21, 2008
    HOW DO YOU GET TO THE FL231 FUSE
  • RCA Master
  • 5,138 Answers
Go to menu then setup see if convergence is listed If not you have a open Fuse FL231.
Posted on Dec 21, 2008
  • 2 more comments
  • ladywinn
    ladywinn Dec 21, 2008
    Yes ,you can fix it yourself Fuses look like small square brown capacitors, but they are fuses next to flyback transfomer on right side 3 of them in a roll it will be the middle one FL231.you can pull top off of them with a pair of needle nose plyers.
  • ladywinn
    IT is on your left bottom board power/deflection board//// board on right side next to it is your SSB board this board has tuner on it.
  • ladywinn
    open is the same as bad not making connection from one point to the other.
  • ladywinn
    You said with christmas you are frustrated and cannot afford a repair person Thank God no one has my bad luck thanks to AT&T and there so called DSL my phone bill went from 43.00 a month to 1,682.00 so they cut off my business phone the one that is in yellow pages so furture customers could call, So now its like starting my shop all over again with no income to do anything,my bank sold to another one bouncing my checks and would not honor my 1,000.00 over draft then disability stopped my ssi ck the one i started my bussiness with because i surpossivly owe on old fine! Not only that i am behind on my rent all of my bills so it looks like after the 1st of 2009 I will be out of business and homeless ,When i started my business i drawed from SSI disability $452.00 amonth WELFARE and they never did any of the things they promised to do to help me under so called Pass to Work Program! If it had not been for the owner of my building letting me trade out work to paint it in exchange for rent i would not have made it at all! So there will be No Merry christmas or a Happy new year for me.Sorry about telling you all of this but justed had to tell someone. Income for this month $75.00 total.
    Ok after telling my stuff heres how you will know which board is what !!! you have 2or3 boards on bottom and 2 boards above the bottom boards the bottom of your chassis on left side is board with Fuses that look like caps but are Fuses 3 of them in a roll the one in the middle is the one that opens and the board next to this board is the SSB board it has your tuners on it you hook your cable to it.Good Luck and if you need anymore help let me know!
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
RCA R61WH76 61 in. HDTV Television Red green line top screen
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 23, 2011 | RCA R61WH76 61" HDTV
Bowed red green lines at top screen. picture looks like it in 3d.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 28, 2011 | RCA HD52W59 HDTV Projection Television
Rca hd52w59 tv has red, blue and green lines at the top and the images are doubled. What is wrong?
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | RCA HD52W59 HDTV Projection Television
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
103 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
