Question about Dell E771MM 17" CRT Monitor
Monitor Problem My monitor screen is just small up in the middle and it wont return back to normal...it's two side r in a kind of arc, what could be the problem do i've to take it to a technician?
  • 624 Answers
This is a duplicate post, click the following link to go to the active posting. http://www.fixya.com/support/t141063-problem_dell_e771mm_17_in_crt_monitor
Posted on Apr 04, 2007
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
Blue sign in middle of computer that say user mode
men it sucks when my pc boots that users mode apperes in my screen ...it apperes again and again ~_~
it wont stop displaying in my monitor
how can i fix it ?
Dec 18, 2009 | LG Flatron L1715S 17" LCD Monitor
Bought the computer (with ECS HT 2000 Dual DDR 800 MB) 2 months ago. Two weeks into it, the screen goes black; but the ''no signal'' that normally appears in the middle of the screen, when the computer is...
Send the dealer a letter informaing him that you intend to file a small claims action against him to recover the $65 and the cost of the computer, because it is defective.
Also notify him that he has 15 days to respond. Then file a small claims action against him to recover those damages.
It would be in your best interest to try to find out what kind of warranty he offers with machines that he sells
Sep 24, 2009 | Computers & Internet
A pink line the whole height of the monitor has
Try setting you screen size to a larger or lower size. and the pixel color. try 32bit instead of 16bit.
Jul 18, 2009 | Acer 22" X223w LCD Monitor
Monitor is enlarged, wont return to normal size
You may have hit the "F11" key which takes the open window to fullscreen. "F11" toggles large, small... If not that, beboot. If that doesn't clear it up, then the display settings have gotten altered. Right click on the desktop, select "settings" and increase the resolution. Windows should prompt you to keep or reject the change. Select yes or no when prompted.
Jan 24, 2009 | Computers & Internet
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
Problem with data cord
Change the data cord if not repaired then change the monitor ,give another companies monitor
Aug 26, 2008 | Philips 105S51 15" CRT Monitor
19" hansol 920p monitor
To my knowledge, it is not the zoom that has to be adjusted but rather the horizontal width, zoom would expand all (to, bottom & both sides) whereas your only concern are the two sides.
Should the horizontal width not fully expand, then there is an internal problem with the horizontal deflection circuitry which could either be the yoke, a capacitor or shunt diodes. In certain instances, a below normal voltage at the mains or the internal power supply could also cause this.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Hansol Multitech 920p 19" CRT Monitor
Monitor Problem
Apr 04, 2007 | Dell E771MM 17" CRT Monitor
Dell E771MM 17" CRT Monitor Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
