Question about Solis Maestro Electric Burr Grinder
Starbucks Barista Burr Grinder (Solis 166) motor does not run
The motor will not run. The burr grinder has been cleaned. It is not clogged. The motor shaft will not turn at all. It appears that the motor has "seized". Where can I purchase a new motor. How does the outer plastic cover come off? Thank you for your anticipated answer.
  • Anonymous Mar 07, 2009
    need to replace starbucks barista grainder motor
  • 1,089 Answers
Hi
Remove bean hopper
Remove grounds hopper
Remove timer knob on the side
Turn the grinder upside down
There are 4 slits on the outside edge.
Insert a screw driver into the **** and pry gently outward with a
little downward pressure on the outside until the side slips a bit.
Repeat on all 4 slits and the shell should slide off.
There is a fuse on the side of the motor that will blow and stop the motor. It is a thermal fuse and should be replaced by a qualified tech.
Posted on May 26, 2009
  • Steve Martin Jun 23, 2013
    I had a similar problem with the hopper door not allowing the grounds to fall into the receptacle and it packed the very fine grounds under the conical burr. I followed the instructions to remove the outer shell and removed the door. The chute that the door is attached to easily pops off and the door is free. Just saved $200.
    New Friend:
Does the motor make noise? If so, it is getting electricity, and it is unlikely to be blown fuse. If there is no motor hum, it could be the fuse, but it could also be one of the switches.
There is a timer switch which can be tested for continuity with a multimeter. There is a pressure switch which senses the presence of the hopper. This switch failed on my 8-10 year old el60, and I was able to clean it with a spray of contact cleaner ( not wd40 - http://www.goldwingfacts.com/forums/2-goldwing-technical-forum/366596-never-use-wd-40-electrical-connections.html can get dirty).
Posted on Mar 01, 2015
I took my Starbucks Barista Conical Burr Grinder apart to clean it, and now I cannot seem to get the top burr back on. This is an old model, purchased in 2000, and has been running great. I used to manage...
I think when you fix the front burr then you need to loose the middle screw. Then it will fix easily.
But don't run it right away.gently tighten the screw and tight until you feel some tightness .Then start the grinder and tighten or loose it according to your grinding specification
thanks
please rate me
Apr 02, 2011 | Starbucks Barista Burr Grinder
It says to "lift the
BURRS are the metal parts that grinds the coffee. There are 2 BURRS in the grinders, The upper burr is normally the one you adjust (Fine or coarse) and the lower or closer to the motor is the one turning during the grinding process.
Jan 25, 2011 | Starbucks Barista Burr Grinder
How to clean burrs
Easiest way run a tablespoon of rice through the grinder.
Apr 25, 2010 | Starbucks Barista Burr Grinder
Starbucks barista burr grinder: the motor runs but the beans won't grind
The drive mechanism from the motor to the burrs has failed in some way. It is necessary to disassemble the machine down to the basic components to determine the fault. Good luck!
Apr 06, 2010 | Starbucks Barista Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
Not fine enough grind
This model grinder won't do espresso. There is a DIY mod available online that involves disassembling the machine, and recalibrating the burrs to produce a finer grind. I did it on mine, it was definitely better, but it's not going to get you to the coveted 30 second pull for your espresso. Search on Starbucks Barista Grinder Mod. It is a great grinder otherwise, very reliable.
Jan 09, 2010 | Solis Maestro Electric Burr Grinder
Oily beans seem to have clogged our coffee grinder up. What can we do?
Rotate the bean hopper counter clockwise until it stops. Lift it off. Remove the outer burr with the 2 wings and clean under the burr. Clean the opening going to the chute for ground coffee(inside where the burr was).
Install the outer burr. Install the bean hopper. Rotate the bean hopper to the French press grind (coarsest) and operate the grinder. This will clean the burrs and the passages. If it starts to clog, repeat the last part to clean the burrs and passage. It must be grinding to go to a finer setting, but you can go to a coarser setting any time. Another thing. Turn the grinder upside down (empty) and rotate the bean hopper back and forth to clean the threads of the adjusting burr..
Dec 20, 2009 | Solis Maestro Electric Burr Grinder
My Barista Burr Coffee Grinder suddenly grinds too fine.
If it is any consolation, mine just did the same thing, now takes too long to grind and it is way to fine dispite a thorough cleaning by disassembly.
Jun 07, 2009 | Starbucks Barista Burr Grinder
Does not grind
Sorry no answer ...i have similar problem described
Mine... sounds like it is working but nothing grinds. Any suggestion no this issue
May 14, 2008 | Starbucks Barista Burr Grinder
Solis Maestro Electric Burr Grinder Logo
965 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
