Question about Fantom Vacums FM760 Twister 500DX Bagless Upright Cyclonic Vacuum
Willnt pick up good...
I have cleared all of the hoses on this vacumn and it works fine with the hose taken out but you put it back in and it don't pick up. I have tryed everything Please help.
I had this problem once too. When the hose is inserted into the vacuum, the floor unit (where the spinning brushes are) becomes the head of the vacuum. In other words, the suction goes through the floor part and then up through the hose and into the vacuum. If the suction is good when the hose is out, the the problem is blockage at the bottom piece. Take the cover off of the rollers (it is one screw then it pops right off) and see if there is a bunch of lint/hair/gunk blocking the suction hole. You could also take the hose part out of the vacuum and look down the empty shaft with a flashlight and see if you see anything there. Hope this helps!
Posted on Apr 12, 2009
    President:
  • 1,462 Answers
Check for blockage in hose
Posted on Apr 04, 2007
Vacuum has been working great. Purchased in April of 2003. Yesterday, while vacuuming, it shut off so I left it off for 30 mins. It started up again fine but now when I vacuum the dirt cup doesn't...
Based on your description, your unit has an air flow blockage. The shutdown sounds like thermal protection. Something is blocked, somewhere. You have to verify that each and every inch of the air flow passageways are open.
Jul 12, 2011 | Vacuums
What do I do when there is no suction. My central vac just stopped picking up and though I emptied the machine and replaced the filter there continues to be no suction.
1. If it's an older model, the hose is likely well worn and probably has leaks at each end where it attaches to the handle and connector at the other end. If this is the case, a new hose is needed.
2. A blockage in the hose. To check the hose for blockages, detach both ends and drop a coin down one end. Lift the hose a little at a time so coin drops out the other end. If it doesn't, there's a clog. Please don't try to take it apart to remove the clog. If you can't get it out, take it to a reputable vacuum repair shop and let them.
best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked
3. Is there suction at the end of the hose, or is it just at the power nozzle there's none. If the hose has good suction, check the power nozzle airway. If it's blocked it can easily be cleared by pushing the clog back toward the brush with the handle of a wooden spoon, or other similar object.
Jan 15, 2011 | Electrolux Pu3650 Central System Vacuum
My vacumn wont pick anything up and it wont self propel. I checked the belt - it is fine.
There are numerous things to check.
  1. Check for hose clog
  2. Brush belt has many hairs and doesn't move
  3. Brush belt broken/loose
  4. Vaccum bag is full
  5. Height adjustment according to floor.
Dec 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
My vacumn wont pick up from the bottom but the hose works fine. I emptied the bag and the green light is on.
Either the glide plate at the bottom is blocked or the belt is broken
Please leave feedback
Thanks
Rob
Feb 12, 2009 | Bissell 3522 PowerForce Bagged Upright...
My vacumn wont pick up from the bottom but the hose works fine, I have an empty bag and the green light is on.
Thanks
Rob
Vacuum not picking up
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
No suction or very little
Make sure you have a good bag installed in the vacuum and the door is properly in place. Remove the attachment hose from the bag chamber and turn the machine on. You should have good suction coming from the hose inlet. If you don't you have a problem in the bag chamber. Bad bag, door is not on correct, door is defective, dirty secondary filter.
Connect the hose back to the machine and pull the other end out from the bottom, and turn the machine on. You should have good suction there. If you don't you have a clog or hole in the attachment hose and it needs to be unclogged or relplaced.
Reconnect the to the bottom. Flip the mahine upside down. Take the screws out of the bottom plate and remove. Remove the brushroller and belt. Turn the machine on and you should have suction at the inlet coming off the brushhousing. It you don't, then you have a clog in the nozzle hose and it needs to be removed. It will probably be more accessable from the bottom side since that is the way that it entered.
Sometimes a suction problem can be confused with an brush problem. The belts on that machine should be replaced every 6 to 8 months because they will strentch and wear. This is an inexpensive maitainance that will dramatically improve its function. Part Numbers are 38528-035 and 38528-034
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Won't pick up
try removing the 4 screws on the bottom of the vacuum and remove the gray hose from the flexible clear hose on the back of the vacuum near the bottom then take a rag and push it through the hose to the outlet on the bottom it is a straight shot it should clean it out. I did this to solve my problem with no suction on the vacuum and it worked. You would be amazed how much hair and dirt are in there. Then just put everything back together and it should work just fine assuming you cleaned the air tube behind the canister too.
Oct 24, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Fantom Vacums FM760 Twister 500DX Bagless Upright Cyclonic Vacuum Logo
234 people viewed this question
Top Fantom Vacums Vacuums Experts
Jose Pino
woodzowl307
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
