Question about Sharp LC-37D7U 37 in. HDTV LCD Television
Sharp TV not displaying the video from PC (RGB to DVI - Input 5)
Sharp TV not "seeing" the video - no Hz being displayed when video out is sent from the PC RGB port.
Audio is working from PC to TV
Signal source on Input 5 and set as Analog PC
tried setting PC to 1024x768 ; 1280x768 ; 1280x720
video setting Picture OPC Off tried On On:Display
tried MENU Setup - but Input Signal & Auto Sync. not selectable (probably because TV not seeing the video input from PC)
tried PC RGB video out to another monitor & it worked
DOES this SHARP TV act as PC monitor?
Why did my omni 100 disply screen shink, how do I fix it
ATI Radeon HD5450 graphics processing unit (GPU) soldered to the motherboard
Figure 3: GPU with fan
  • Interface: GPU chip soldered onto motherboard
  • Maximum resolution:
    • HDMI TV resolution: up to 1080p at 60 Hz*
    • HDMI PC resolution: 2560x1600 at 60 Hz
    • DVI TV resolution: up to 1080p at 60 Hz*
    • DVI PC resolution: 1920x1200 at 60 Hz
    • VGA resolution: 2048x1536 at 60 Hz
You need to use the ATI Catalyst Control Center software to optimize display.
See this page for the Omni 100 drivers
See HP Support
Aug 27, 2014 | HP Omni 100 PC
How do I display what the hz my sharp LC-60LE630U is doing so I can know if and when I am operating @ 120hz which is why I purchased the tv. Checking online, they say most of these HD receivers only...
Tap the info button on the TV remote to see what resolution and frequency is being sent to the video board then the signal is upscaled to 120 Hz the numerical value displayed when info is tapped is the input signal value before processing to the panel resolution and frequency
Sep 30, 2017 | Televison & Video
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
I'm trying to use my 6 yr old Sharp TV as a remote monitor for my MacBook laptop. The Sharp manual says that port 5 is the correct port for PC hook up. So, I'm hooking up the laptop's mini DVI port to the...
You need to set your MAC video resolution to the native resolution of this TV in PC mode, please read your manual to find out what that is, if the resolution is set too high, the TV will not be able to display it.<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-bidi-font-size: 12.0pt; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Aug 27, 2010 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    Display
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    Miscellaneous
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    Power
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    Sustainability
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    What type of audio jack rgb/dvi in on rear of lg 50ps3
    the dvi out of pc via adaptor to hdmi on tv has no audio,ok.
    so LG diagram shows separate audio into Audio in RGB/DVI.
    Resulting in video in on HDMI ok,but audio on RGB.Can not get both together.
    Fix is revert to DVI to RGB lead with audio on RGB/DVI input.
    The audio jack would only work with mono plug for audio in, to RGB.
    Dec 08, 2009 | LG Televison & Video
    Want to connect my Sony vaio VGN-A250 to Sharp 19'' LCD TV
    Your laptop will have a VGA output or possibly a S-video out. For the VGA you'll need a standard VGA cable. Plug the cable in to your laptop and the PC input of your TV. If your TV does not have PC input it may have a DVI input. IF it does you can use a VGA/DVI adapter to plug it in. If it doesn't have a DVI input you can use the S-Video output on your laptop with a standard S-video cable. After the connection to your TV is made you will have to toggle alternate display by pressing and holding your [Fn] key and pressing F4, or F5, or another F# key. It's the one that looks like a TV screen. Press once to turn on output, press again to turn off your laptop screen, press again to go back to laptop screen only
    Feb 10, 2009 | Sony VAIO A250 Notebook
    I want to make conection betwen tv.sharplc-42d62u topc
    To my knowledge, the Sharp LC-42D62U do not have a VGA or DVI inputs. While they lack dedicated PC inputs, you can make use of one of the HDMI inputs, use a DVI-to-HDMI adapter and connect to a computer that has a DVI output.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
    Nov 11, 2008 | Computers & Internet
    Mitsubishi xc-3716c monitor
    ttl is in short from Transistor-Transistor Logic.
    Apr 18, 2008 | Computers & Internet
    Sharp LC-37D7U 37 in. HDTV LCD Television Logo
    745 people viewed this question
    Top Sharp Televison & Video Experts
    Jaime Hernandez
    Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
