Question about GE GDS18LCR Bottom Freezer Refrigerator
The refrigerator is warm, but the freezer is fine
The refrigerator will cool down for a while, then a few days later, will be warm compared to the freezer. Turning the control up on the refrigerator part seems to have no effect.
eagle338
  • 4889 Answers
SOURCE: my refrigerator is warm
This problem is due to plugged defrost drain line..Click on the link below(i have already solved this problem).Note that this is generic problem with refrigiratorsand the troubleshooting procedure is same for any model or brand..
http://www.fixya.com/support/t226483-kenmore_50222000_help_me_please
Posted on Nov 06, 2007
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
aasc
  • 1606 Answers
SOURCE: running but not cooling
Pull the refrig out , unplug , and on the back , remove the 8 " X 10 " panel . Behind this panel , is the main control board . On this board , you will see a blue plug ,with 3 larger wires going to it , which you need to unplug .
You will need a short piece of insulated wire , with both ends stripped about 1/4 inch .
Looking at the plug , you will see : wire1 wire2 space wire3 . With the piece of wire , insert 1 end into wire2 , and the other end into wire3 .
Plug the refrig back in . Looking in the freezer section , behind the crisper , after about 1 min , you should see a " red " glow .
If no red glow , this means your defrost heater AND bimetal need to be replaced . Unplug the refrig , remove jumper wire , and plug the blue receptical , back onto the board . Reinstall the panel .
To replace these , remove the food in the freezer , and remove the inside freezer panel ( 4 screws hold this panel on ) , and the heater is below the coils ( 2 screws ) , and the bimetal is clipped on the top of the coils , a 1 " cylinder , with a pink and blue wire going to it .
Part number for the heater WR
Posted on Oct 06, 2009
heatman101
  • 43501 Answers
SOURCE: GE Monogram Freezer wont defrost
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
  • 2699 Answers
SOURCE: freezer door was left open, now after one day freezer is not cold
you can unplug it and let it defrost on it's own or you can melt out the air ducts,you'll have to shut down the freezer,remove the shelves and remove the inside back wall of the freezer section and melt out all the ice in the right hand corner and any ice on the coil.when melting out the air ducts be careful not to damage any of the plastic or styrofoam on or inside the wall,heat up the area with a hair dryer for a couple of minutes and then move to the coil,after a minute or two go back the the air duct,when you think it's melted out enough turn the freezer back on and with your hand check to make sure the air is blowing into the fridge side,if you can feel air blowing then your all set,if there's any ice left in there the defrost will take care of it.if you have another fridge to put your food in or if the food can't be refrozen i'd just unplug it and let it melt out on it's own over night and you can clean it out while everything is out of it.let me know how you make out and good luck,hope you didn't loose that much food
Posted on Jun 06, 2010
My refrigerator and freezer will work fine for a day or so, and then cool poorly. The compressor runs continually when it cools poorly. If I unplug it and plug it back in a few seconds later it will run...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | GE Refrigerators
Refridgerator part warming up.unplugged for a day.worked fine for a few days.warming up again.Possibly the defrost heater?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | GE Profile Arctica Stainless Steel Top...
Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Refrigerator gets too warm, then too cold, back and forth...
heatman101
Oct 26, 2009 | Frigidaire FRT21H8 Top Freezer...
In my side by side samsung RS2534WW the rerigerator is warm
I read elsewhere that if you hold the power cool and power freeze buttons down for 12 seconds it will restart the system. I did it the other day (because we were having the same issues) and it has seemed to work for the last few weeks. Frige temp stays at 34F and freezer temp stays at -2F
Mar 13, 2009 | Samsung RS2534 Side by Side Refrigerator
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator and Freezer stopped cooling after intermittent noise
Hello
if the ice maker arm is down regardless of the water being off the valve will energize ( dry ) no this will not effect cooling
Apr 12, 2017 | Kenmore 73503 Stainless Steel Bottom...
Fridge and Freezer losing cooling
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
May 27, 2008 | Fisher and Paykel Active Smart E522B...
GE GDS18LCR Bottom Freezer Refrigerator Logo
63 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
