Question about Riccar 8955 Upright Vacuum
Reset button on riccar upright vacuum
My vacuum quit while vacuuming and it says on ;the vac to push the reset button, i can't find it anywhere. the model is8925
I CANT SEEN TO GET THE TOP TANK TO SNAP BACK IN, IT KEEPS SPILLING THE WATER AND SOLUTION
Posted on Dec 21, 2008
Where is the thermal reset button
Riccar uses an external thermal reset which is more reliable than most brands which use a thermal reset built into the motor. On your Riccar it will be on the back on the bottom left. It is a little tiny button that you epwill hear "click" when you push on it if it has been popped. If not it will not push in and you won't hear the click. The older models did not all have a reset button. If you have to keep pushing the reset it means that most likely you have a clog somewhere or the bag is full. It's rare but occasionally a thermal reset button may go bad and need replaced.
Apr 10, 2016 | Riccar 2000 4000 series Upright High...
Where is the reset button on the riccar 300 upright?
If you are facing the back of the vacuum the reset button will be towards the bottom of the vacuum.
Dec 06, 2014 | Riccar Vacuums
Where is the reset botton on riccar
The reset button is on the lower back of the vacuum
Sep 18, 2014 | Riccar 8955 Upright Vacuum
Why does the riccar vacuum reset button not depress?
In my experience the Riccar requires reset when it has ingested something that jams the roller such as the fringe of an Oriental carpet. Be sure to clear any such obstruction, then I use a ball point pen to press the button. It does not move very far to accomplish a reset.
Jun 18, 2014 | Riccar 8955 Upright Vacuum
I have a riccar vibrance red vacuum, just purchased with in 6 months and the roller brush wont go on and the reset button doesn't seem to push in or work I now live in Hankinson, ND 58041...there is a...
The reset button only pops out if the vacuum motor overheats. It does not affect the brush roll. If the motor is running the problem is most likely a broken or stretched belt.
Jul 26, 2011 | Riccar 8955 Upright Vacuum
Our Riccar SupraLite Upright Vac used to glide across the floor so easily, but now we have to push it pretty hard. This just recently started. What can be wrong?
Suggest you check the wheels to see if they are moving freely. Also check the beater brush to see that it is moving freely. Be sure the belt has not broken. If it has, replace with a new one. Also take the time to clean the beater brush of any debris and spray a little WD40 on both ends of the beater brush axle.
Sep 12, 2010 | Riccar 8955 Upright Vacuum
Absolutely no power. No light or anything. Is
There's a small white button on the back of the machine near the left wheel. Use a paper clip or similar item to push that in.
Jul 04, 2010 | Riccar 8955 Upright Vacuum
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
Where is riccar reset button>
The reset button on your model 8955 is in the back, on the left side at the bottom. It is a white button
Jan 15, 2010 | Riccar 8955 Upright Vacuum
Riccar 8955 Upright Vacuum Logo
742 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
quennie732
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
