Question about Car Audio & Video
Bmw 2000 740i (e38) Car stereo/Audio Shorts out & On.
Some how my Car stereo keep's cutting in and out. The Screen does not show the info it's just blank and the navi if i have a disc in it just locks it up and it will not eject.. The Radio works but it cut's out and you have to turn the radio on and off to get it to work. What Cause's this? How Can i Fix this problem? Should i upgrade?? Can you recommend a certified BMW audio technician in Los Angeles????
  • agstanley Apr 14, 2009
    I have exactly the same problem with my 2001 BMW 740i (E38). Blank navi screen; radio/CD player cuts out after about 2 1/2 minutes (must turn if off and back on again for it to work, but again for only 2 1/2 minutes); navi CD will not eject - VERY FRUSTRATING!
  • 117 Answers
Nev comp is your problem check to see if have power to unit
if no power check fuse if ok must replace nev unit
Posted on Jul 07, 2009
The built in sat nav screen keeps going up and down without switching on and also the radio cd does not switch on. any advise would be appreciated
bmw navigation radio cd changer repair
www.hitechserv.com/electronics-repair/oem-navigation-dvd-cd.../67
We repair all models of BMW GPS CD Changer Stereo ... shows on the screen, no audio, display shows no navigation disc but there is a disc inside, do not play CD. ... If there is sound but your blue tooth or satellte tuner is not working "if your car is equipped with blue ..... The MK3, MK4 computers has a GPS module built in.
3 Series (E46) built-in Sat Navs - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=862860
PistonHeadsJun 9, 2010 - I don't know much about the OEM sat navs, other than that they cost no less than ... would need to be re-positioned and CD player becomes redundant. ... on forums, they do the job, just about and sometimes not too well at all.
Nov 01, 2015 | Cars & Trucks
Stereo fuse keeps blowing
Check wiring for any shorts. If none found remove radio and harness and test on a seperate battery or power supply. If still blowing there is a problem with the stereo.
A good local car audio shop can help you out if you need.
Jan 04, 2014 | Pioneer Car Audio & Video
My reciver is showing protect after i installed it. what can i do?
Check your system for bad speakers, and any shorts or grounds in the speakers and speaker wires.
Sep 22, 2011 | JVC AM FM CD DET FACE CAR STEREO
My kenwood car stereo model no. KDVMP5343U is showing protect while switching on
check all your speakers and speaker wires for shorts or bare spots. if they check out you may have a bad amplifier ic in the deck.
Aug 17, 2010 | Kenwood Car Audio & Video
NEED STEREO WIRE COLORS FOR 1988 BMW 735I
red = constant live 12v
brown = negative ground
violet = ignition live 12v
white = electric antenna (rear screen)
the speakers will be twisted pairs, i can not remember which is left and right but the grey stipe and brown strip are negative the others are positive.
If in doubt get a pro to install for you as you could cause damage if you connect wrongly.
Nov 25, 2009 | Car Audio & Video
02 5 series bmw stereo
Hello rbs845,
Most vehicle audio integrated phones use a ground on a specific wire from the receiver to activate the "mute" function. If the wire contacts other wires or shorts to ground, it can cause the receiver to signal an incoming call or mute. Without the exact make and model of the receiver, it's not possible to point you to a specific wire color to look for. I'd make sure that ALL wires that are not used are securely insulated and kept from touching other wires or metal behind the dash.
Hope this helps.
Sep 24, 2009 | BMW 02+ 3 5 X5 M3 Series Car Radio Wiring...
What am I doing wrong? 94 jeep GCL caska 1605 dvd
OK, HERE IS WHAT I SHOW.
DID U KNOW THEY MAKE AN ADAPTER HARNESS THAT ALLOWS YOU TO PLUG DIRECTLY TO FACTORY HARNESS? NO CUTTING WIRES. THESE ARE AVIL FROM ANY LARGE RETAIL STORE LIKE BEST BUY. PLEASE RATE MY HELP, THANKS!
1994 Jeep Grand Cherokee Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Violet/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: Green/Red
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
Aug 03, 2009 | Car Audio & Video
Aftrmarkt cd player 2004 bmw 330i
2004 BMW 330i Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White
Left Front Speaker Positive Wire (+): Yellow/Red
Left Front Speaker Negative Wire (-): Brown/Orange
Right Front Speaker Positive Wire (+): Black/Red
Right Front Speaker Negative Wire (-): Brown/Orange
Left Rear Speaker Positive Wire (+): Yellow/Black
Left Rear Speaker Negative Wire (-): Black/Orange
Right Rear Speaker Positive Wire (+): Blue/Black
Right Rear Speaker Negative Wire (-): Black/Orange
pls rate
Jul 22, 2008 | 2003 BMW 330
Car Audio & Video Logo
1,339 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
