Question about GE Profile PDW8400J Built-in Dishwasher
C5 error on GE Profile dishwasher
It asks for a reset but the reset does not take and beeper just goes off and the C5 error shows again
  • Anonymous May 03, 2009
    all bottons are off except for the start reset on. beeper goes on an on and the unlock button will not respond.
    President:
  • 373 Answers
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Posted on Dec 21, 2008
The pump on my GE Profile dishwasher is not draining.
If it is the last cycle only it is not the pump. It is a wiring or timer issue. Most likely the timer.
Nov 11, 2009 | GE Profile PDW8400J Built-in Dishwasher
I have a GE Profile Triton Dishwasher and it has worked fine for about 8 years. Suddenly it will not reset. The reset light blinks after reset but you can not choose a normal cycle afterwards. I shut of...
Hello, how are you?
It sounds like you have a stuck key on the keypad, preventing you to push any other key.
I've seen this problem many times in the past 4 years.
Good luck.
Ned
Sep 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
GE profile Dishwasher gives an error: C5
Dec 21, 2008 | GE Dishwashers
Error code: "Ih" on GE Triton XL. What is reset combo?
After leaving the dishwasher locked with the error code still showing, I returned to find that it had reset itself and run through the full cycle.
Problem solved itself.
Dec 11, 2008 | GE 24 in. GSD4320Z Built-in Dishwasher
Error code
you have set it to start after a one hour delay- just press the start delay button until it cycles through past 24h and you will get back to the immediate start mode...
Oct 12, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
GE Profile dishwasher GSD4930X88WW will not start C3 error code
The wiring diagram for GE dishwashers is usually found under the dishwasher, take the bottom panel off, then look for a envelope about 3"x5" up against the bottom side of the floor of the dishwasher, right under/behind the front edge. If its not there it makes servicing it tougher. C3 code means the drain sensor is not functioning, C7 code means the temperature sensor is not functioning.
As to the voltages used, I would only know that by looking at the wiring diagram (which I do not have).
Jan 14, 2008 | GE GSD3800G - Multiple Color Built-in...
GE Profile PDW8400J Built-in Dishwasher Logo
911 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
